Hi all,
I have a 325i E reg car and the batteries have leaked all over the SI board. It doesn’t look very happy. Just need a good working board or if need be the whole cluster?
Tah
325i cluster board
- fixedwheelnut
Is it salvageable? I modify mine using a AA x 2 battery holder and mount some rechargeable batteries on the outside of the cluster with velcro.
https://www.amazon.co.uk/AA-Battery-Hol ... 5130&psc=1
- Brianmoooore
The board is lacquered, but if the crud has got under it, into the thin tracks around the battery area, then it'll be a major, time consuming job, for someone with much better eyesight than mine, to repair it.
Never understood why anyone would want to fit an external battery tray. There's no worthwhile advantage.
- fixedwheelnut
I did it on one of my earlier ones so I could disconnect them when I left the battery off for a long time and also if the batteries do leak they wouldn't damage the board, plus the added bonus of about five minutes to change them if I needed toBrianmoooore wrote: ↑Sat Jan 02, 2021 8:06 pmThe board is lacquered, but if the crud has got under it, into the thin tracks around the battery area, then it'll be a major, time consuming job, for someone with much better eyesight than mine, to repair it.
