BMW e30 325i Touring Royal blue metalic very High spec leather Ac etc
Place where dreams come true - threads will be deleted 60 days after last post.
bmw-mad
Post Tue Aug 31, 2021 6:21 pm
BMW e30 325i Touring Royal blue metalic very High spec leather Ac etc Image
Bmw E30 325i Touing
1989 G reg
Royal metallic blue Sports Automatic
A very honest car needing a freshen up, this has been parked up indoors for almost 12 years!
Original supplied By Prophets BMW in Solihull
Very high spec from the factory
Royal metallic blue
Sports grey leather interior with rear headrests
M Tech leather steering wheel
13 button obc which works
Map light rear view mirror
Cruise control which works
Air conditioning again which works but will need an overhaul
Rear load cover with dog net
4x electric windows
Top tint front windscreen
Headlight wash wipe
15" bbs alloys wheels
Se side skirts
Etc
Interior is overall in good order everything  works as it should, the dashboard is cracked, and roof lining is just starting to sag at the rear.
Body work is overall good, all the usual areas are solid, jacking points, scuttle, boot pockets, etc only bits which will need sorting is the sunroof panel and the seems on the inside of the tailgate have come away. The paint overall is decent has a few touch ups but with a good detail paint should come up nicely.
Mechanically the car starts at the turn of the key, runs quite well but does need going over as it been parked a while, a short spin arround the block and it pulls and changes gears as it should holds temperature as it should.
History file is very impressive, a A4 folder full of invoices, All the previous mots from new, spec sheet, and loads more. Car is HPi clear and has covers just over 120k and is backed up with fsh stamped in the service book.
Complete owners pack, 3 original matching keys,
The car will.need the v5 applying as the previous owner could not find it.
I am pricing the car at £6000
Located in Birmingham 10.mins from the nec.
