Step 1 I'm going to strip the E39 and would like some help on what I need to keep that isn't the obvious?
Turns out that it will cost more than double that at the place I have asked.DanThe wrote:I must have read that wrong first time, are you suggesting it costs £900+ to modify the original loom and ECU to work?
EWS isn't the problem. OP has all the EWS bits, and they're easy to fit to an E30, providing a reasonably effective immobiliser.Driftben wrote:have you looked into a EWS delete option?
also have a read through this, guys who have done the conversion is the key as they have over come this already.
http://www.bimmerforums.com/forum/showt ... WS-Problem
All the other signals? being inquisitive, apart from speed signals which others would it be looking for from the chassis loom?Brianmoooore wrote:EWS isn't the problem. OP has all the EWS bits, and they're easy to fit to an E30, providing a reasonably effective immobiliser.Driftben wrote:have you looked into a EWS delete option?
It's all the other (lack of) signals from the car chassis trhat's the problem.
chu346 wrote:Dan, you had one sensor down, but the system still had 3 other sensors to take readings from.
The problem with fitting dsc is that apparently the e39 clocks & e39 wheel sensors will need to be fitted.
Other option for dsc is mk60 system from e46 M3 but fitting that in total should cost £2000+
You just cant help yourself........you got it working by calling everyone you knew for information, the very fact you have the audacity to ask people for help and then come out with insults like the one above can only lead me to believe it must be some underlying way to mask a lack of ability, its very easy to copy, very easy to ask others and pass off as your own, do something original and amazing, but I doubt you can.DanThe wrote:Ive got the MK60 ABS on my track car, it cost me less than £100 in bits because I didn't feel the need for F1 technology
Some information for you Chu.chu346 wrote:I was informed that the e39 abs talks to the instrument cluster. Mk60 can run standalone though.
Demlotcrew wrote:You just cant help yourself........you got it working by calling everyone you knew for information, the very fact you have the audacity to ask people for help and then come out with insults like the one above can only lead me to believe it must be some underlying way to mask a lack of ability, its very easy to copy, very easy to ask others and pass off as your own, do something original and amazing, but I doubt you can.DanThe wrote:Ive got the MK60 ABS on my track car, it cost me less than £100 in bits because I didn't feel the need for F1 technology
