Z3/E36 rack with M60 and manifold clearance
E30Ad
Post Sun Sep 30, 2012 10:18 pm
Just wondering if anyone has had experience with fitting either an E36 or Z3 steering rack on their E30 M60 conversions... If so I was wondering if this has any great impact on clearance for the exhaust manifolds??
I am having custom manifolds made but just debating whether to swap the rack at present, will do so prior manifolds being made to ensure good clearance. Just wondering if anyone has fitted this combination already and what your experience of the impact on rack clearance was.
Cheers,
Ad
E30Ad
Post Mon Oct 01, 2012 9:15 am
Aghh right cheers for the heads up mate, shall do some more research!
Did you space the subframe 20mm?
Cheers,
Ad
FormerMember
Post Mon Oct 01, 2012 4:33 pm
E36 rack is thinner than E30 rack, so it actually helps with the oil sump clearance.
Other than that, there shouldn't be any major differences, the driver's side manifold is a tight fit anyway.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Driftben
Post Wed Oct 03, 2012 8:45 am
I have a E46 rack on mine and the clearance sump wise is about 5mm but exhaust wise you will have to modify anyway if you use a E30, E36 or E46 rack :wink:
Tighter than a nuns chuff
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
Phill172
Post Wed Oct 03, 2012 9:21 am
I have a e36 rack on mine, no clearance issues, although I am running the 20mm sub spacers
SHAZ325iSPORT
Post Wed Oct 03, 2012 9:27 am
Im using a z3 rack and have custom manifolds
No issues at all
E30Ad
Post Wed Oct 03, 2012 8:08 pm
Cheers boyo's will give. Z3 rack a bash and see what happens my fab/welder is shit hot so no doubt he'll have no probs with the clearance... Let's hope anyway!!!
