Thanks guys.
How to tell M60 from M62
E30-830
Hey guys, I'm going engine shopping in the local scrap yards tomorow to look for an M62B44 for my E30 and was just wondering how to tell an M62 from an M60. Markings and engine numbers, etc. Also what cars they are found in.
Thanks guys.
Thanks guys.
slip_osms
E30-830 wrote:Hey guys, I'm going engine shopping in the local scrap yards tomorow to look for an M62B44 for my E30 and was just wondering how to tell an M62 from an M60. Markings and engine numbers, etc. Also what cars they are found in.![]()
Thanks guys.
Hi there ! I can give you some info.. maybe it is useful !
M60 3.0-, 4.0-liter dohc V8 (OBD-I)
1994-1995 E34 530i, 540i, including touring
1994-1995 E32 740i/iL
1994-1995 E31 840Ci
M62: 4.4-liter dohc V8 (VANOS OBD-II)
1997- E39 540i/touring
1996- E38 740i/iL/iS
1996-1999 E31 840Ci
and here you have info about engine numbers on all the BMW engines. (where you can find the number, and what it means)
www.ge39.com/files/zeigeinfo.pdf
sorry if my english is not correct, but I'm from Romania. Cheers !
E30-830
Thanks for the info slip.
This will come in handy.
glenn
- Engine Transplant Services
the m60 has the crank sensor / impulse wheel on the front of the crank...behind the belt pulley,
the m62 has the crank position sensor on the gearbox bell housing, as the impulse / position wheel is on the flywheel
hope this helps
hope this helps
slip_osms
good tip. i will note that. thanks
you guys are crazy.. with all this M60 conversions... but I love it.. and I am one step away from doing it ! I just need the engine now.. everything else is prepared..
(oh.. I forgot, i am preparing my car for drifting)
E30-830
Thanks glen,
Will be able to identify them straight away now.
FormerMember
M62 has also electric-controlled thermostat, whereas M60 has the conventional unit.
M60 has double chains and M62 single, easily checked via the oil filler cap.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
200272
Dont forget the 3.5 M62.
They had water cooled alternators.
