Servos
alpina123
Post Sun Feb 16, 2014 11:13 am
Hi does anyone know what is the best servo setup to run with an s50 3.0 conversion? Is the golf/Clio the best or is it better to mount it behind the glove box or use a remote servo off an e12 ? Thanks
jmc330i
Post Sun Feb 16, 2014 11:36 am
Clio servo. If you move the servo over towards the nearside wing you may even get it fitted without having to mod the inlet plenum too much (you will need a longer brake from an E34 to run from the pedal, along the bulkhead to the servo).
James
'91 325i Sport
'93 318i touring 16v
alpina123
Post Sun Feb 16, 2014 12:27 pm
Okay so is it not a good idea to run it inside the car?
jmc330i
Post Sun Feb 16, 2014 1:14 pm
I know a few people who run Clio servos inside for V8 conversions, but there's no need with an S50 conversion. Fabricating a mount that securely holds the servo isn't too easy, it is certainly easier to leave the servo in the engine bay and move it over slightly.
Plus if its a road car, you lose the glovebox.
James
'91 325i Sport
alpina123
Post Sun Feb 16, 2014 1:18 pm
Okay mate cheers also I know you used a mk1 golf servo is a Clio a lot better?
moggie
Post Sun Feb 16, 2014 1:26 pm
ive used the clio servo and moved it over 50mm and i have not needed to cut the plenum it has lots of room now,instead of using the e34 brake bar i fabricated an extension piece out of 2 of the threaded ends joined together to make 1 longer end which screws onto the threaded bar
alpina123
Post Sun Feb 16, 2014 1:38 pm
Oh okay cool have you used a 750 master cylinder?
jmc330i
Post Sun Feb 16, 2014 4:07 pm
You only need the 750i master cylinder (or other 25mm master cylinder) if you're using brake calipers with larger pistons than the standard E30 calipers. I used the shorter Audi 25mm master cylinder for clearance to the inlet elbow (my conversion was done long before the idea of moving the servo was thought of) but mine is running M3 brakes, and even then the 25mm m/c is a bit much.
I did drive it for a few months with the standard 325i brakes and 25mm m/c and the brakes were not good.
James
'91 325i Sport
daniboi328
Post Fri Apr 18, 2014 12:00 am
When fitting the Clio servo is moving it over 50mm a must do thing ?
reggid
Post Fri Apr 18, 2014 2:15 am
how much difference in diameter the clio?
E30 325is with M20B31
