S54 vs S50 3.2
thed4ppa
Post Sat Jan 04, 2014 6:05 pm
So with most of the parts for my little E30 project purchased / on order I'm down to sourcing an engine etc.
I can see the s54 is clearly 24hp more that the s50 3.2 which is a nice start, but the conversion is quite costly. Is it worth the extra effort or for a substantially smaller figire is the s50 3.2 a good choice, how well do they respond to tuning? Realistically I think part wise the s54 with a decent manifold will be around 4500k the s50 would be a fair bit cheaper!
I have seen a complete e30 running a e36 3.2 engine too which is tempting.
If the S54 is the hands down better option and basis, then ill push along with that.
jmc330i
Post Sat Jan 04, 2014 6:23 pm
I've not priced up an S50 conversion since I did mine, but a decent S50 conversion will be £5k-£6k. I'm sure you could add another £1k-£2k for an S54, unless it gets bodged together...
James
'91 325i Sport
'93 318i touring 16v
Post Sat Jan 04, 2014 11:27 pm
Stick to the plan :)
ajay
Post Sun Jan 05, 2014 7:24 am
As above, if you can strech to an S54 do it, you will not regret it.
There is quite a bit more of a difference than you think :D
thed4ppa
Post Sun Jan 05, 2014 10:14 am
Thats it then, a decoy had come up so was just a thought. 344hp sounds better to start with any way ;)
What day are you off to Autosport Dan?
reggid
Post Wed Jan 08, 2014 8:41 am
S54 handsdown, better parts availability and aftermarket bits due to presence in the US market
E30 325is with M20B31
