EWS help / b30 and b32 x20 pin locations
Peet
Post Wed Nov 16, 2011 9:43 pm
Ews help
Not E30 related but someone might be able to help,
I am putting my S50B30 out of my E30 into the M coupe shell i've just bought.
The coupe has a EWS ecu fitted but no engine loom, my S50 doesn't have EWS can i just get a E36 M3 loom without EWS and not use it or if i get a loom for a M3 with EWS would i be able to use my engine ECU along with the coupes EWS unit?
Post Wed Nov 16, 2011 9:55 pm
Dont get what you mean exactly :mad:
But, the ECU, EWS module and key chip all have to match, you cant mix them.
If your engine has no EWS then it will go straight in without problems, all you need to do is join the two starter wires in the EWS plug that comes with your car body loom.
As for engine loom you must use the S50B30 loom, you cant use B32
Peet
Post Wed Nov 16, 2011 10:03 pm
Sorry wasn't too clear on that.
I need a S50B30 loom (will be easier than changing the one in the e30 to fit) and was was just waying up if i'd need a ews one with the coupe being fitted with ews (everything is there up till where the engine loom should plug in),
But if its just a matter of linking the starter wire the and using my ecu and a standard b30 none ews loom then that seems like the way to go.
Andy325i
Post Wed Nov 16, 2011 10:13 pm
Peet wrote:Ews help
We need pictures! Not that I have an M coupe fetish! :o:
Peet
Post Wed Nov 16, 2011 10:20 pm
There is a build thread under the other bmw section :)
Peet
Post Sun Jan 22, 2012 2:03 pm
Bit of help needed, I’ve eventually got round to starting the coupe but it just turns over but won’t fire.
I have fitted a S50B30 engine, loom and ECU out of a none EWS car , but the coupe still has all the EWS system fitted (it’s a 1999 car)
Is there anything I’d need to do to make it start?
Jimbob
Post Sun Jan 22, 2012 2:25 pm
Should just fire up by the sounds of it as your ECU isn't looking for an EWS signal.
Peet
Post Sun Jan 22, 2012 2:57 pm
thanks
wondering if it could be a fuel pump relay issue, think the B30 has it in the harness and the Z3 has one in the dash somewhere
ian332isport
Post Sun Jan 22, 2012 6:26 pm
Peet wrote:Bit of help needed, I’ve eventually got round to starting the coupe but it just turns over but won’t fire.
Although the S50B30 doesn't have EWS2, it has what could be called EWS1. I believe it's similar to the e30 OBC code function. If you feed 12v to a particular ECU pin, it immobilises the engine. When you fit an S50B30 into an EWS2 car, the EWS system sends enough voltage to the ECU to kill the engine. If you cut the wire on pin 7 of the X20 connector, it should start.
Ian.
Peet
Post Sun Jan 22, 2012 9:39 pm
Thanks, checked and the bloke i got the loom off has already done that for us.
Done a bit more messing and it looks like the b30 and b32 have different pin locations in the x20 connector.
Post Sun Jan 22, 2012 10:30 pm
Is the fuel pump priming on ignition then running when cranking?
Peet
Post Sun Jan 22, 2012 10:41 pm
DanThe wrote:Is the fuel pump priming on ignition then running when cranking?
No the pumps not running, we can't get power to switch the pump relay, the 12v supply is there but we only get 3v on the switch side.
Post Sun Jan 22, 2012 11:09 pm
The fuel pump should prime regardless of EWS working or not, it has to be a wiring or ECU problem, as long as the ECU has Permanent Live, Ground and Ignition it should send the signal to the fuel pump relay to prime, have you checked for spark or injector pulse?
Peet
Post Mon Jan 23, 2012 12:49 pm
DanThe wrote:The fuel pump should prime regardless of EWS working or not, it has to be a wiring or ECU problem, as long as the ECU has Permanent Live, Ground and Ignition it should send the signal to the fuel pump relay to prime, have you checked for spark or injector pulse?
Thanks for that
will have a look into them
done a bit more messing and it looks like the oil level light on the dash comes on when i switch the ignition on and stays on for a bit then goes off and comes back on when i turn it over. Makes me think some of the wires on the coupe are in different locations to the M3. (6 or 7 wires are in differnt locations going off the colours)
will try and get the pin outs for both and compare them
Peet
Post Wed Feb 08, 2012 12:39 pm
Has anyone had experience with fitting a S50B30 into a S50B32 car?
When I turn the ignition on now the engine will turn over and the idle control valve is making a noise (like it used to in my old car), its just not firing and the fuel pump isn’t switching on.
Coupe Wiring (car loom side of X20 plug same as M3 Evo S50B32)
1 oil temp brown/red
2 oil level brown/white
3 fan climate control black/red
4 DME to compressor relay black/blue
5 pressure switch black/yellow
6 climate control module black/violet
7 ews green
8 not used ---
9 speed output black/white
10 reverse light blue/yellow
11 engine coolant temp 1 brown/yellow
12 engine coolant temp 2 brown/violet
13 fuel pump relay -dme imob device brown/green
14 DME relay red/white
15 starter - zke control unit black/yellow
16 data link white/yellow
17 data link dme white/violet
18 starter black/yellow
19 service reset white/green
20 engine speed black
21 ignition green
22 fan (ebox), oil level, reverse light, oxeygen sensor green/white
23 oil pressure brown/green
24 not used ---
25 alternator blue/yellow
Engine Loom (Engine Side of the X20 plug, M3 S50B30)
1 --- ---
2 --- black/red
3 --- ---
4 ac compressor control black/blue
5 normal speed relay black/grey
6 climate control module violet/grey
7 starter immobilization relay green
8 check engine grey
9 --- brown/red
13 oxygen sensor, fuel pump relay green/violet
14 speed out black/white
15 wiper module black/yellow
20 Engine Speed black
21 ignition green
22 reversing light switch green/white
24 instrument cluster white/black
25 alternator blue
I’ve moved the following pins locations on the engine side of the connector to bring them in line with the coupe side
Pin 9 has moved to pin 1
Pin 14 has moved to pin 9
This leaves pin 14 empty, does anyone know what I need to connect to this (I am hoping this is the issue that’s causing the fuel pump not to work)
The only other pin I am a bit unsure about is pin 15
Any help is appreciated as I am slowly losing enthusiasm with the car now after weeks of messing with wires and not getting anywhere.
Peet
Post Wed Feb 08, 2012 9:03 pm
All sorted now :D
Jimbob
Post Wed Feb 08, 2012 9:15 pm
What was it then mate?
Peet
Post Wed Feb 08, 2012 9:21 pm
The fuel pump relay didn't have a wire to switch it, so just wired it into a switch live (fused) and the relay is worked, it started first time, simple things are always the most annoying to find
Jimbob
Post Wed Feb 08, 2012 9:32 pm
Isn't it just :banghead:
Glad you got it sorted!
