s50 swap
Peet
Thu May 05, 2011 11:24 pm
Most stuff i've tried has been from Bm, always try and use dealer stuff if possible on our projects :)
Peet
Sat May 07, 2011 1:01 pm
Well ordered a full set of vanos seals, gotta be worth a try as the current ones look a bit perished and the filter is blocked up with gunge so going to give it a good clean out at the same time.
ian332isport
Sat May 07, 2011 2:15 pm
Peet wrote:does anyone know if it should make a noise like a pressure release valve when the engine is stopped ?
I'm pretty sure mine does. It's sending pressurised oil into the accumulator so it has pressure for the next startup.
Ian.
Peet
Sat May 07, 2011 2:35 pm
Reeto, makes sense that it would do that :)
Dave_M3
Sat May 07, 2011 10:17 pm
Ian.
Pretty sure I've heard M52s do it too.
GermanGorilla
Sun May 08, 2011 2:40 pm
Hi,
Check the Vanos solenoids are
working correctly.
A blocked Vanos filtre will also
contribute to poor running as
will leaking seals etc.
If the Vanos is unable to function
correctly then the engines performance
will be restricted.
Are you sure that the BMW Garage that
you visited did not check for this ?
Its one of the cheapest easy= fixes for
the S50 B32.
Regards,
The Gorilla.
Peet
Thu May 12, 2011 8:01 pm
Well pulled the vanos off it last night and all the seals had gone hard, have replaced them all and it now seems to pull alot smoother than it was doing, going to take it on a run and see how it does, still don't seem as good as my mates m3 but its getting there.
Peet
Mon May 16, 2011 10:58 pm
Well after a long run in the e30 its still playing up and over fueling :( gutted now as i've runout of ideas and stuff to try.
Really going to have to way my options up now for the car and conversion
jonnie
Mon May 16, 2011 11:00 pm
Have you tried a different ecu?
Mon May 16, 2011 11:08 pm
Can you list what you have tried?!
Did you unplug the loom at all?
Peet
Tue May 17, 2011 9:37 am
Stuff that i've replaced
Maf, ICV, all vacum pipes, all inlet seals, injectors, coil packs, crank sensor, knock sensors, cam sensors, lamba sensors, vanos seals, blue temp sensor, fuel pressure regulator, fuel pump, fuel filter,
Stuff i've swapped for others just to try
Ecu, vanos contol unit, exhaust manifold,
At first i didn't want to be messing with the loom but I decided i had to give it a try, so its been off and had all the joints re-made (incase of bad connection) and i've had all connectors cleaned
irish320i
Tue May 17, 2011 12:44 pm
Have you done a compression test and cylinder leakage test sounds like it has to be a mechanical issue at this stage if all the testing you've done has been carried out correctly. Is there any way the chain timing could be off?
Regards
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
Peet
Tue May 17, 2011 1:01 pm
not done one yet, i've had to order a adaptor for our compression tester (the pipe wasn't long enough), so hopefully that should be here soon then it can go back in the garage (once i finished the car thats in at the moment) and have a look at it again.
will do a leak test on it aswell whilst i am messing
not sure about the timing being out as i've not had it to bits but suppose its worth a check
Dave_M3
Tue May 17, 2011 9:24 pm
compression and leakdown test may reveal something. I thought it had already been done before swapping all the other bits and pieces.
Peet
Tue May 17, 2011 11:45 pm
In a way i hope it does then at least i know what it is but on the other hand i don't want to find anything major as i know once it comes out for a rebuild it'll not end up going back in.
rallygaz
Fri Jun 24, 2011 8:36 pm
any news on this m8 ? is it sorted ??
Peet
Thu Jun 30, 2011 9:33 pm
it did seem to run right on its trip to le mans, managed to get 35mpg out of it
but its time for a new project now so i am going to take the engine out and sell it on and sell the car, unless someone would want it as it is
Thu Jun 30, 2011 11:29 pm
What did you change in the end to sort it?!
I got 31mpg (ish) on the way back from the 'Ring in it.. Filled it at the station by the 'Ring, then the light came on my 55L tank as I drove up the road from the ferry @Dover.
RoadHazard
Fri Jul 01, 2011 5:57 am
30+ mpg 8O
I only got like 20 out of mine. But that's mixed between stop-and-go and high way driving.
Dave_M3
Fri Jul 01, 2011 10:11 am
Jhonno wrote:What did you change in the end to sort it?!
Thats better fuel economy than a few M40s I have driven :P
Peet
Fri Jul 01, 2011 12:08 pm
the rubber coupling between the gearbox and prop bust the weekend before we was going to le mans, and after changing that it seems to be running fine now, very odd i know but must of just been a bit of vibration through the gearbox to the engine that was causing it.
was well impressed with the MPG, my mates coupe did the same and that was with us playing on the way there (there wasn't anythin between them :D)
its back down to low 20's round town though
Fri Jul 01, 2011 12:25 pm
8O 8O VERY odd.. You can't complain that it is solved though.
Low 20's around town is to be expected! I get that with my 328i..
Don't fancy keeping it now then? I still miss my S50'd e30.. Although a 328i makes it slightly less painful. What are you planning next?
Peet
Fri Jul 01, 2011 4:56 pm
Haha yeah no idea how its worked but just glad its right
I do like it but just think its time to change again, this is the longest i've managed to keep a car :P
Not sure whats next yet, stuck between going back to building a rally prep'd classic or building something with a big V8 (hot rod or cobra)
Fri Jul 01, 2011 5:18 pm
I am the same.. 20 cars now in 9 years.
The e30 though, I had for 6years! Didn't get bored of that one.
I'd love to do an LS3 powered e36 Touring on gas.. :twisted:
Both of those options sound like fun though!
RoadHazard
Tue Jul 05, 2011 8:45 am
How fast do you guys drive on average to get 31-35 mpg? Is this with the 6-speed tranny?
Tue Jul 05, 2011 8:50 am
5 speed box 3.25 diff
It was mostly a relaxed 75/80mph cruise speed.. With the odd bit of 'play time' :)
E30_Crazy
Tue Jul 19, 2011 9:11 am
Peet wrote:Haha yeah no idea how its worked but just glad its right
Had a skim through the thread but didn't pick up on whether it is a 3.0 or 3.2?
You still thinking of moving on to another project?
Tue Jul 19, 2011 9:21 am
3.0
Peet
Tue Jul 19, 2011 12:40 pm
its a 3.0
yeah time to move on now and get another project, all E30 stuff has gone now apart from the car
still thinking hot rod or kit car but we have been offered another Z3M coupe thats needs work so might be tempted by that
