what happens if oil filter shatters to pieces in a e30s50b30
turk
Post Sun Jan 01, 2012 3:05 pm
Mate, This is AWFUL! I have just read through this thread and im shocked !
I think you would be wise to have someone dismantle the car and get it back to original state, engine out, oil drained, oil cooler cleaned and checked for flow. Especially if little bits of filter have been floating around the oil system! Then build back up from there!
Sounds like they have stolen your manifolds, and rad too :eek:
Take as much advice from this forum as possible. Everyone who has posted really know their stuff and we have all had trouble with bodgers and the only way to fix it is to start from scratch!
I think you're looking at a lot of money in labour to sort this.
Good luck pal ! Look forward to seeing this get sorted! get stuck in!
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
craigieeb
Post Mon Jan 02, 2012 8:46 pm
So what happened with this..?
Did you get the car back and your cash or did you roll over and hand over the rest of the money?
e30s50b30
Post Mon Jan 02, 2012 10:11 pm
i went like hulk hogan with a trailer drove the e30 back and had my mate load the m3 on the trailer didnt pay waiting for them to sue me .
Post Mon Jan 02, 2012 10:14 pm
How does it drive?
e30s50b30
Post Mon Jan 02, 2012 10:29 pm
faster than the m3 was ! very fast !
e30s50b30
Post Mon Jan 02, 2012 10:34 pm
i met a guy in a vxr astra that was trying to be clever wiped the floor with him on the way back so yes frankestein is fast !
eko
Old timer
Post Mon Jan 02, 2012 10:38 pm
What gearbox/diff have they used?
e30s50b30
Post Mon Jan 02, 2012 11:43 pm
Used diff from e34 525i I think not sure gear box is zf from m3
e30s50b30
Post Mon Jan 02, 2012 11:44 pm
WAt cooling fans are u guys running ?
leeparkes
Post Mon Jan 02, 2012 11:54 pm
e30s50b30 wrote:Used diff from e34 525i I think not sure gear box is zf from m3
Doubtfull.
What was your E30 before the swap? ie 316i etc...
You might still have a small case diff on. 8O
Post Mon Jan 02, 2012 11:56 pm
leeparkes wrote: You might still have a small case diff on. 8O
my thoughts too... :cry:
e30s50b30
Post Tue Jan 03, 2012 12:00 am
It was a 325 I coupe
e30s50b30
Post Tue Jan 03, 2012 12:01 am
Did they steal my e34 diff if the 325 did not need replacing ?
leeparkes
Post Tue Jan 03, 2012 12:03 am
Id still take a look. If you count 8 bolts holding the diff back plate on your ok....ish. :)
e30s50b30
Post Tue Jan 03, 2012 12:04 am
The power is brutal though it's crazy scary kind of !
e30s50b30
Post Tue Jan 03, 2012 12:06 am
I will check first thing am I need to see 8 bolts right ?
leeparkes
Post Tue Jan 03, 2012 12:16 am
Needs to look like the one in the middle.
There will be a tag on one of the bolt holes, scrub it up with sandpaper and see what the numbers say.
You could still have a 3.91 ratio. No wonder it feels quick. :D
e30s50b30
Post Tue Jan 03, 2012 12:30 am
I will check and let you know ! Hm I'm gonna stylist mechanics now tired of rip offs lol , appreciate the pics
Post Tue Jan 03, 2012 1:40 am
What so you gave them a M3 cab and £3K? :eek:
e30s50b30
Post Wed Jan 04, 2012 11:03 pm
i got my cab back building it up again now bought a s50b32 to go in plug n ply simples lol got a old mate doing it no tricks
