air box
hi guys,got my engine in but have hit another problem.ive used mk1 golf gti servo but i still dont seem to have enough room for the air box.mines the metal box type with the plastic connection pipes,do these have to be shortened?or do i need the other air box?any help before i attack it with hacksaw.cheers.
ian332isport
- Contact:
No chance of using any sort of vacuum servo in the standard location with an S50 I'm afraid. Oh, and please don't be tempted to put a big notch in the plenum. You'll only succeed in blocking half the air flow into No6 cylinder.moggie wrote:no,i didnt no i had to if using the golf servo?
Ian.
ian332isport
- Contact:
Those pipes are shaped to fit into the ends of the throttle bodies (with an o-ring seal), so you can't trim that end. The other end is a bellmouth, so you don't want to be touching that either.moggie wrote:why cant you shorten every connection pipe from the airbox to the engine,thus moving the complete air box away from the servo
I never understand why people always mess with the important bits instead of removing/moving the obstacle/offending unimportant bit.
but obviously it can't be that bad looking at the number of butchered plenums I have seen and NO engine failures reported. Or is everybody just keeping quite???
ian332isport
- Contact:
It's not so much that the engine will fail, it's more that it won't make all the power it should.UweM3 wrote:but obviously it can't be that bad looking at the number of butchered plenums I have seen and NO engine failures reported. Or is everybody just keeping quite???
Ian.
Wait till the manifold doesnt fit and a M50 cast manifold goes onian332isport wrote:It's not so much that the engine will fail, it's more that it won't make all the power it should.UweM3 wrote:but obviously it can't be that bad looking at the number of butchered plenums I have seen and NO engine failures reported. Or is everybody just keeping quite???
Ian.
