Help with spark plugs
Porthos
Post Fri Jan 01, 2016 8:06 pm
I am in the US but, I own a UK market 318i Touring with the M40B18 engine in it. I bought some NGK BPR6ES spark plugs to replace the ones that are in the car now because I can not tell when the last time they were done. First, I can not get the 19mm socket into the plug hole it is too big(that's what she said!). Is there a special socket? Second, I just wanted to make sure that they plug I had would fit the 19mm socket and the plug is larger than the socket. So I am lost on what should be a very easy task and would like some help.
jimmyspeed
Post Fri Jan 01, 2016 8:21 pm
Check your tool roll in the boot/trunk - there should be a long hexagonal tube which pairs with a grey handled bar that slots in to change your plugs. If not you can buy special tools
maxfield
Post Fri Jan 01, 2016 8:32 pm
It should be a 21mm socket you need.
You can get spark plug sockets from most motor factors which are reasonably thin walled.
Porthos
Post Fri Jan 01, 2016 8:41 pm
Thanks for the help I will go look right now and let you know.
Porthos
Post Fri Jan 01, 2016 9:06 pm
So I went and looked for the tool kit. Now this car is 25 years old. It has 25 years worth of service records, the original first aid kit, the jack, and I am the 2nd owner but, it does not have the tool kit.
maxfield wrote:It should be a 21mm socket you need.
The 19 won't even fit into the spark plug whole so I am not sure going bigger will be better.
maxfield
Post Fri Jan 01, 2016 9:09 pm
Spark plug sockets are thin walled to fit into tight spaces. Have you tried a socket on a new plug so you know the size?
They are either 21mm or 16mm (bar some new BMWs which are 14mm double hex) and I'm pretty certain they are 21mm.
Porthos
Post Fri Jan 01, 2016 9:11 pm
Ya it has to be a 21mm because I read on another website it was 19mm and that definitely does not fit.
Porthos
Post Sat Jan 02, 2016 1:31 am
So I can't find a tool kit or that specific tool to remove them. I am new to E30s and especially the touring model can anyone tell me where in the car I should find the tool kit.
jimmyspeed
Post Sat Jan 02, 2016 9:45 am
no worries - your specifically looking for this
It should be in a tool roll in the rear pods - i would check the spare wheel area as well. Although it sounds although yours is missing.
If you can't find the tool buy a socket one like maxfield said or get one like this - Image
summit racing or jegs will have tonnes
reggid
Post Sun Jan 03, 2016 2:33 am
spark plug socket is a deep socket and correct size is 13/16" or 21mm
E30 325is with M20B31
Porthos
Post Sun Jan 03, 2016 6:33 am
reggid wrote:spark plug socket is a deep socket and correct size is 13/16" or 21mm
I understand that but, it will not fit into the spark plug hole.
jimmyspeed
Post Sun Jan 03, 2016 7:00 am
[quote="maxfield"]Spark plug sockets are thin walled to fit into tight spaces.
Porthos
Post Sun Jan 03, 2016 7:05 am
:hammer:
reggid
Post Sun Jan 03, 2016 7:55 am
yeah how about buy a dedicated spark plug socket. A generic one fits fine....
jimmyspeed
Post Sun Jan 03, 2016 9:39 am
Porthos
Post Mon Jan 04, 2016 5:57 am
I will get one in the morning.
Porthos
Post Tue Jan 05, 2016 3:20 am
This is what I am working with \
Porthos
Post Tue Jan 05, 2016 9:50 pm
I will give that a try when it is not raining. El Nino has officially arrived in Southern California.
fixedwheelnut
Post Tue Jan 05, 2016 11:28 pm
This is what you need 16mm thin wall 3/8th drive plug socket
http://www.justoffbase.co.uk/Spark-Plug ... oCgYDw_wcB
Porthos
Post Wed Jan 06, 2016 2:15 am
If my 16mm does not fit I will give that one a go.
Porthos
Post Sat Jan 09, 2016 10:55 pm
Ya, it is the 16mm. Going to go look for the correct plugs.
Porthos
Post Tue Jan 12, 2016 7:18 pm
Pretty sure I ordered the correct spark plugs this time. SHould find out in a couple of days. Never had this much trouble with such an easy piece of maintenance.
Porthos
Post Wed Jan 20, 2016 12:52 am
Finally got the correct plugs and they installed beautifully, thanks for looking out W
illnz. I have some pics too. The ones in their were the Bosch ones which are a tad bit more expensive.
