Sourcing M42
cee
So my M42 (currently at 155k) is pretty haggared, and I've come to the conclusion that it may work out cheaper in the long run to just swap it out for one in decent condition. Especially when it subtracts £10 a month from the insurance! (Don't ask, I don't understand it either).
So, how much would I be looking at for a tip top (standard) M42. My gearbox is fine, so without would be cheaper I guess. Rough prices please!
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
Andyboy
- Alpina Colada
I have a very good one from a '95 318ti auto. £200 but you'll need to swap the sump, manifolds and loom. It's a 92'000 mile unit and as sweet as.
cee
Unfortunately that's not standard so the insurance won't withstand.
Andyboy
- Alpina Colada
It's the same short engine. Swap the E30 bits over and it's the same thing.
cee
I doubt that would stick with the insurance companyAndyboy wrote:It's the same short engine. Swap the E30 bits over and it's the same thing.
DHFiS
Exactly what do the insurance company want?cee wrote:I doubt that would stick with the insurance companyAndyboy wrote:It's the same short engine. Swap the E30 bits over and it's the same thing.
cee
Non standard engine is uninsurableDHFiS wrote:Exactly what do the insurance company want?cee wrote:I doubt that would stick with the insurance companyAndyboy wrote:It's the same short engine. Swap the E30 bits over and it's the same thing.
Standard engine swap is the same/cheaper price
Andyboy
- Alpina Colada
What would be non standard? An M42 is an M42.
cee
This is very true, however the insurance company would most likely say that because it is not from a model called "318iS" it's not the same. You know how difficult they are...Andyboy wrote:What would be non standard? An M42 is an M42.
Andyboy
- Alpina Colada
So an E36 318iS is not a 318iS? Despite the block and head numbers being identical, it's 'not the same engine'?
Good luck with your search.
Jos
e36 M42s are more common, cheaper and wil have less mileage on them so it's the logical choice. If your insurance company can tell the difference between an e30 M42 and an e36 M42 after ancillaries and manifolds are swapped they are doing well, they are the same engine as Andy said, same head and block numbers.
No change in capacity, and a factory fitted engine. Don't see what their issue is, have you actually asked them this or are you just assuming?
'94 e36 tree climber
cee
e36 318iS is M44 is it not? The M42 was in the standard 318.
As stated previously this is just assumptions, but seeing as the M44 is a 1.9 I think they may have spomething to say about it!
Andyboy
- Alpina Colada
No. Until January 1996 the 318is and Compact Ti were 1.8 M42.cee wrote:e36 318iS is M44 is it not? The M42 was in the standard 318.
rix313
E36 318is up to 1995 is M42. '95 onwards is M44.
Buy an E36 M42, fit the E30 bits as you have to to fit it and they will not know as it's the same engine any way.
cee
Hmm okay well will look into it, thanks
Jos
e36 M42 - which is now in my touring.
This one is slightly different as it has the serpentine aux belt
retroboyo
Ive been thinking of an M42 conversion from a M40. Is the wiring straight forward?
redcar
Yes.retroboyo wrote:Ive been thinking of an M42 conversion from a M40. Is the wiring straight forward?
