oil cooler adapter
Pongo1602
Mon May 23, 2011 3:18 pm
Hey all, does anyone know where to source this part so I can run a remote oil cooler, Thanks
http://www.m42club.com/forums/album.php ... ctureid=85
http://www.m42club.com/forums/album.php ... ctureid=84
rix313
Sun May 29, 2011 3:23 pm
Judging by the equipment in the back ground this is a one off piece.
balilu91
Tue May 31, 2011 10:28 pm
i believe they are called oil sandwich adapters or plates. you should find what you need by googling it
rix313
Mon Jun 13, 2011 3:59 pm
You wont find something like that off the shelf. Mocal do a take off plate which I had fitted to my car:
Only problem the way it's designed, the unions would hit the alternator. A guy on M42 club had one fitted to his Z3 M44 and he welded some unions to it and made it work.
Why are you wanting to run an oil cooler? Are you seeing VERY high temperatures frequently?
TamTom
Sat Jun 25, 2011 11:08 pm
cant you use the original 325 oil cooler?
rix313
Sun Jun 26, 2011 10:48 pm
Different engine, different parts...
HairyScreech
Sun Jun 26, 2011 11:20 pm
http://www.thinkauto.com/takeoff.htm
type d or type h on that link anygood?
