bmw e30 320 -86 m50swap
Eeken98
I dont get spark or fuel when i try to start and im 100% sure that carnk shaft sensor is working and all that but wont start
Does rev. counter register cranking RPM?
Five pin DME relay in the correct socket? The one with a wire connected to the centre pin of the base.
Does the DME relay click when you pull it out or insert it with the ignition on?
Eeken98
it dosent register crank rpmBrianmoooore wrote:Does rev. counter register cranking RPM?
its correct socket and it click when i put it in
but its an automatic harness so i have to jump two cabels but i dont know where
Does the car crank/starter motor work?
Eeken98
ya the motor is cranking goodBrianmoooore wrote:Does the car crank/starter motor work?
In that case you must have already sorted the loom to remove the auto start inhibitor.Eeken98 wrote:ya the motor is cranking goodBrianmoooore wrote:Does the car crank/starter motor work?
What colour is the label on the engine ECU and is it a 413?
Eeken98
colour is green and its an 405. and its an m50b20 engineBrianmoooore wrote:In that case you must have already sorted the loom to remove the auto start inhibitor.Eeken98 wrote:ya the motor is cranking goodBrianmoooore wrote:Does the car crank/starter motor work?
Is this correct for the M50B20 engine?
According to this list, the 405 is for the M50B25. On your other thread, you mention an M50B25 vanos with a 413 red label ECU.
http://www.bimmerboard.com/forums/posts/93519
