m52 hard to start when hot
shedrool83
Post Sun Apr 24, 2016 6:04 am
Think about bidding an e38 728i its a 1998 with a single vanos .
It has a problem with starting when upto running temp.
From what the owner said it starts first turn cold and will start when hot but if started right way when hot.If its left it stuggles to start.
Would i be right in thinking temp sensor or cps?
Or is there something else that can be more worrying / expensive
Post Sun Apr 24, 2016 10:42 am
Can't see it being anything expensive. Leaking injector is another possibility.
shedrool83
Post Sun Apr 24, 2016 12:50 pm
Brianmoooore wrote:Can't see it being anything expensive. Leaking injector is another possibility.
Thanks Brian
I did think about leaking injector but convinced myself it would cause issues when cold too. :o:
