M50 stroker Turbo
Acaciastrain360
Post Sun Oct 19, 2014 10:49 am
I am stroking my m50b25 nv with M54b30 rotating assembly, but I want to go that one step further and turbo it too. My question is compression ratio's... Do I just follow the steps to turbo'ing a M54? Or do I have to do some sums for the M50? Any help would be great, cheers from the dirty south
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
age
Formerly twist316
Post Sun Oct 19, 2014 11:20 am
wasting your time and money in my opinion. just turbo the b25
M40 rightness if you can get to 6000rpm noone can hear your tappets
craigieeb
Post Sun Oct 19, 2014 9:06 pm
What sort of power are you looking to achieve..?
ross_jsy
Post Sun Oct 19, 2014 9:15 pm
It is not as easy as following instructions for an m54 as m50's have a 1mm lower deck height. AFAIK there is no out of the box solution, however I have done the calculations and found some Wiseco pistons that work and give an 8.7:1 compression ratio.
Got to ask yourself why though, a turbo m50 makes loads of power.
Acaciastrain360
Post Mon Oct 20, 2014 6:57 pm
It was more to the point of being different to other M50 turbo's that's all! I see a lot of M50 turbo's on the web but not so many in the UK for a start, so I thought this would be a cool idea. Thanks for you're input anyway though dudes...
