What a ******* nightmare!
leeparkes
Post Sat Mar 15, 2014 3:56 pm
Getting a clio servo of a car with the engine still in! :cry:
All was going well, removed the inspection panel in the wing and got it all undone easily. Trying to get the bastid out of the car was another story!!
I even cut some of the shell to give more room with no joy, spent 2 hours and walked away with nothing :x
Is it actually possible to get one out of one with the engine still in?
nickso
Post Sat Mar 15, 2014 4:01 pm
I'm certain I got mine out of a car with the engine in.....I remember it wasn't pleasant.
'88 e30 328i M52 track bint.
dooce
Post Sat Mar 15, 2014 7:49 pm
I didnt get a clio servo for mine, but I'm certain I remember someone mentioning that going from inside the car is the way to do it.
maxfield
Post Sat Mar 15, 2014 7:52 pm
Fairly certain you can undo the engine mount and squeeze them out.
Anything French is not nice to work on :(
Post Sat Mar 15, 2014 8:07 pm
Lee you must be a real tight c00nt! :D
http://www.ebay.co.uk/itm/Renault-Clio- ... 2a368231d9
Post Sat Mar 15, 2014 8:14 pm
I only ever attempted this if the engine or head was missing from the 'orrible french turd. £5 a time at my local breakers.
mattxr2
Post Sat Mar 15, 2014 10:02 pm
iv done it twice and first time was a pain in the arse, second one i took out took ten mins
leeparkes
Post Sat Mar 15, 2014 10:51 pm
Which route did you take it out Matt?
It would of been freebie! and the inner jew in me took over, wish i hadn't of bothered! i was in a right state when i come out,
i was fookin furious! :)
mattxr2
Post Sat Mar 15, 2014 11:17 pm
i cut removed the brake lines the first time and pulled it out, i removed the master cylinder the second time i think and it was easier to get out. it was 2 years ago so i cant really remember but it is doable without cutting anything
leeparkes
Post Sat Mar 15, 2014 11:55 pm
As soon as i got the master undone i pulled it downwards and out the way, when i say downwards i mean i popped the reservoir off and yanked the master right down till it was under the rack.
Dont know if it made a difference being as the engine was the 1.4 16v type but either way throughout the job i kept thinking
"why the fook would Renault put an inspection cover there when all you can really do is look!" :mad:
