has any one put a s50 oil filter housing on a m52 engine and had issues with the vanos oil pipe..
the banjo bolt dosent screw into the filter housing as its too big..
any idears?
cheers
ps i have fitted the housing to put a oil cooler on the engine
s50 oil filter housing on m52 vanos oil pipe fitment
rich318i
you need the adaptor, stepped banjo
Open it up to the correct thread, M14Sx279 wrote:has any one put a s50 oil filter housing on a m52 engine and had issues with the vanos oil pipe..
any idears?
cheers
maf260
I had the same issue. You need to open it up to the correct thread. I also needed a M3 power steering pump which also needed a little engineering to get the pipes to fit. It definitely wasn't the straight forward swap I was told, but now fitted it does a good job of keeping the oil temp under control.
Sx279
all sorted cheers people i made a new pipe with an fittings and braided hose..
i havent got pas pump on my e30 dont feel the need for it and as irs a track car less weight haha...
thanks again
thanks again
rich318i
only reason for the pump is for the OEM style
Rallyprep_UK
- formerly Driftnething
I have a batch of conversion banjo bolts.
Makes life easy if you are not comfortable modding the housing...
