Hiya
Could you guys pls tell me what the differences are in a m50b25, and a m52b28 heads pls
also, are the cams different, and can you put a m52 head on a m50?
if I was to put 2.8 pistons in a m50 block, which would be the best head to use for a turbo project
Difference in head?? & turbo question
Quaser
rich318i
pistons wont fit without some major boring out from 75 mm bore toQuaser wrote:Hiya
84 mm
Quaser
According to realoem - both pistons are 84mm
ross_jsy
Ignore anything Rich says, he is the zone retard.
You wanting to build a stroker turbo? I would just use a standard m50 to be honest. They take 500hp with nothing more than a MLS and ARP head bolts, if it pops, stick in another £300 m50. A stroker would cost a fair whack more.
Quaser
thanks - so std m50 bottom end, and std head then - no need for double intake cams or anything like that??
rich318i
Quaser wrote:thanks - so std m50 bottom end, and std head then - no need for double intake cams or anything like that??
your in a world of problem and yes the bore is 84mm my mistake
ross_jsy
No, would imagine there are some gains to be had from purpose designed turbo cams but it's expense that isn't really needed.
Have a read through Craig's build thread in the turbo section to give you an idea of a good set up.
reggid
i would have thought you would know the difference between bore and stroke since you seem to be so good at stroking it....rich318i wrote:Quaser wrote:thanks - so std m50 bottom end, and std head then - no need for double intake cams or anything like that??
E30 325is with M20B31
rich318i
Me too i was crossed eyed at the time seeing the postreggid wrote:i would have thought you would know the difference between bore and stroke since you seem to be so good at stroking it....rich318i wrote:Quaser wrote:thanks - so std m50 bottom end, and std head then - no need for double intake cams or anything like that??
