Smashed sump, now running strange
M1ke30
My car being as low as it is decided to hit the sump off a suspect price of road put a huge hole in the sump. The engine moved that far back it crushed the PAS cooler pipe on the M3 steering rack.
Anyways, fitted a new sump and PAS pipe and sump guard. The problem is now it's running really strange engine vibrates slightly between 1000-1300rpm(clutch in or out) it stalls really easy at parking speeds. Like pulling up you're drive withought using the throttle. It also feels slightly under powered from what it normally feels like and a lot of throttle delay under 2500rpm. And finnaly it takes ages to start, although it always does.
Any idea on what this could be???
Thanks.
Thanks.
Damaged engine mounts, perhaps?
Check the engine to body earth strap is intact.
M1ke30
Engine mounts seem fine, the engine has returned the exact same location as before and can't see any signs of stress around the mounts. I'll check the earth in the morning.
rich318i
many problems it can be
There are, and the next step should be to hook the car up to a computer.rich318i wrote:many problems it can be
Symptoms you describe would fit a duff cam sensor, but that's not the only possibility, and difficult to associate with the sump incident.
M1ke30
I'll see about hooking in up to a computer, anyone have any idea where he diagnostics plug might be on the M52, I know DanThe did the wires for the guy who done the conversion before I bought it.
I also forgot to mention that the car sat for about 3.5 weeks without being turned over. I was kinda hoping that it was a blocked fuel system. Was going to change the spark plugs, fuel filter and put a cleaner through for the injectors. And see if I got anywhere with that. U think that's a waste of time??
M1ke30
Oh, and the exhaust pops just once on startup. Never heard that on any car at all before.
dave525
could be a valve timing issue.Was the oil pump ok.Cant really see how it could have jumped but all your symptoms sound like it.
dave525
Also could be crank sensor or disc related.
M1ke30
So really if it's a sensor issue it should show up on the computer for diagnostics eh??
Theoretically, yes.
M1ke30
Next question. Lol is the diagnostics port the circular one in the engine bay or should I be hoping that there is a rectangular port been wired in inside. Car was a 316 and now has a M52b28 engine if I haven't mentioned that before.
On a normal E30, yes, the diagnostic socket is the round one in the engine bay. However, your M52 one could be anywhere, assuming it's been fitted at all...
M1ke30
it was DanThe that did the loom for the guy who done the swap, hoping its all there
Best drop him a line then...
M1ke30
Not sure if you'll be able to here the engine clearly but it sounds/feels like a misfire when pulling away at very low Rpm's
Also exscuse the squeaky steering coloumn. Always seems to happen when it doesn't get driven for a long time.
http://i305.photobucket.com/albums/nn22 ... 12dc00.mp4
rich318i
that wine really doesn't sound good what is that?
M1ke30
That's the PAS pump. Not an imminent problem, just waiting on it failing and I'll swap it out. More concerned about the engine just now. Lol.
Diagnostic port is in the original E30 position, as per this picture
M1ke30
ya, got you PM, thanks. the problem turned out to be an earth strap.
been running a dream all week now! in love again! lol
Speedtouch wrote:
Amazing how often this turns out to be the case with such issues, yet people will replace all manner of parts before checking such a simple thing!Check the engine to body earth strap is intact.
rich318i
Great news!!!M1ke30 wrote:ya, got you PM, thanks. the problem turned out to be an earth strap.
