m52 shopping list
heathy325
Post Sat Nov 02, 2013 8:24 pm
hi am just about to start the conversion have purchased an 1995 328i cabriolet auto as the doner car and was just after a list of parts i need to remove and any extra bits that might be worthwile swapping as i have the car hear, i know i need another brake master servo but not sure which one is best and the manifolds i can customise myself, is the loom easy to modify? or is it easier to buy a loon from hear allready to plug and play?also if its a home loom mod how easy is the ews to remove
cheers mark
Post Sat Nov 02, 2013 9:10 pm
Only extra bit you might want to keep from an E36 is the steering rack.
Loom is dead easy to modify (basically cut the E36 plug off of the end and splice an E30 one in its place), but for those who don't fancy this easy job DanThe on here will do the job for you.
He can also disable EWS, but if you have the whole donor car, why would you want to?
Standard brake servo can be used if you move it over a bit, or the preferred choice for a smaller diameter one is one from a plastic winged Clio.
heathy325
Post Sun Nov 03, 2013 12:21 pm
brill thanks for that the only other thing im wondering about is the electric fan wiring what fan switch do i use and any thoughts on which fan is best to use
AndyZippy
Post Sun Nov 03, 2013 1:26 pm
Hey man, i put my own full shopping list at the top of my build thread, if it's of any use :)
http://www.e30zone.net/modules.php?name ... c&t=240819
Electric fan wise i'm using a 14" ebay one dan recommended (also using his auto fan loom), works perfectly, no problems sat in traffic at all :)
Motorhole
You can use the E36 fan from the donor, the cowling just needs some hacking about and you need to make some little brackets to bolt it to standard holes in the E30 front panel.
Two-speed temp switch is used for the fan, screws into the side of the rad. If you use an 80-degree thermostat, I think it's an 80/88 degree switch, I forget. Someone will no doubt confirm that.
Don't forget if you're using the EWS from the donor, you need the key (chip can be removed and put into an E30 torch key), the transponder ring from around the ignition barrel, the ECU and the EWS control box.
Post Sun Nov 03, 2013 10:45 pm
FYI I dont just hack the C101 off and graft it to the E36 loom :D
I modify the E36 loom to get it as small and as close to an E30 loom as possible, which takes many hours
heathy325
Post Mon Nov 04, 2013 8:37 am
thanks guys i was considering on using the fan from the doner but looks like its seized :(
jimbom30cab
Tech 1 freak
Post Fri Nov 08, 2013 5:03 pm
Factory finish that loom Dan, you know if you covered it in silicon or bumper gel you could get at least another £20 for them
pritts
Post Tue Nov 26, 2013 8:15 pm
if i was ever to do another m52 conversion, i would tell dan to do the loom for me again again, the standard was exception and oem finish, and the car fired up first time after installation :)
Post Tue Nov 26, 2013 9:04 pm
Still got your E30 dude?
heathy325
Post Wed Nov 27, 2013 10:22 am
I'll be sending it his way soon don't worry :D
pritts
Post Tue Dec 10, 2013 9:18 pm
DanThe wrote::cool:
soz for late reply just been busy with work etcc...yeah sold it over a year ago now, was running 233 hp when i sold was a animal, will build another one day, hows you beast???
Post Tue Dec 10, 2013 10:22 pm
pritts wrote:
DanThe wrote::cool:
All in here :D - http://www.e30zone.net/modules.php?name ... c&t=107482
