Block hose to matrix
rich318i
Post Thu Aug 22, 2013 8:52 pm
Does the e36 Block hose to matrix fit ok to the E30? ordered one and think i made a boo boo!! as i cant remember what hoses we used for it when the conversion was done.
part No. 64 21 1 394 293
Motorhole
Post Thu Aug 22, 2013 9:06 pm
Not in my case it didnt! Block to matrix hoses are a pita. Could butcher something from a scrapyard to bodge it, but the proper way is to make one up from various silicone hose fittings or use some of that wire reinforced silicone hose. It doesnt kink. Can't remember what is though, 19 or 21 mm IIRC...there's a photo in my build thread.
rich318i
Post Thu Aug 22, 2013 9:12 pm
think i should of just got the e30 hose for it as my mate said but thought fook it didnt want it in bits just to see what the hoses are so took a gamble
rich318i
Post Thu Aug 22, 2013 9:28 pm
Motorhole wrote:Not in my case it didnt! Block to matrix hoses are a pita. Could butcher something from a scrapyard to bodge it, but the proper way is to make one up from various silicone hose fittings or use some of that wire reinforced silicone hose. It doesnt kink. Can't remember what is though, 19 or 21 mm IIRC...there's a photo in my build thread.
Cant see them mate only your rad ones
rich318i
Post Thu Aug 22, 2013 10:08 pm
anyone got anymore info for the block to heater matrix hose??
Motorhole
Post Thu Aug 22, 2013 10:38 pm
Here you go :)
rich318i
Post Thu Aug 22, 2013 10:43 pm
like it how much did they cost?? and what clips did you use?
Motorhole
Post Thu Aug 22, 2013 10:57 pm
20 - 25 quid for a metre of hose. Clips are t-bolt clips. All from Auto Silicone Hoses. I will check this weekend what ID I used if you want.
rich318i
Post Thu Aug 22, 2013 11:01 pm
Motorhole wrote:20 - 25 quid for a metre of hose. Clips are t-bolt clips. All from Auto Silicone Hoses. I will check this weekend what ID I used if you want.
please mate cheers. wanted to fit it all this weekend but like to get it right with the mm's of the hose's
Gregg83
Post Fri Aug 23, 2013 12:58 pm
I used E34 hoses and they fit fine :)
Motorhole
Post Sat Aug 24, 2013 9:50 pm
22mm id it was. Fits to block fine but a bit big for the matrix inlet/outlets. Slip a small bit of 16mm id hose on each one as a reducer.
