and i'v noticed that the round plastic connector, that "plugs" into the inlet, (on the underside, in the middle
was a bit moist around the join, and seemed loose,
there's a canny gap between it and the manifold,
I can see the retaining tab is still there, but when the whole thing is pushed back onto the inlet,
the end of the tab gets pushed away from the "tab bracket" if you know what I mean.
so
Does anyone have a solution for this to be secure?
or
should I just araldite it into place??
