speed sensor now sorted
jimmymig
Mon Dec 31, 2012 2:18 pm
hi all got a m52 in my e30 but my car has no speed sensor wiring! will it have to be remapped or is there another option?thanks jim
Mon Dec 31, 2012 2:53 pm
All you need is a diff sensor and a set of E30 clocks, dont you have this?
jimmymig
Tue Jan 01, 2013 5:03 pm
yes got both but no wire in plug on the e30 harness cant remember the pin number :(
rich318i
Sat Jan 12, 2013 8:22 pm
pin 9 e30 to pin 20 e36. i did the same thing, all the wiring had been cut back and looking nice and didnt want to start looking for the pin20 wire so i just took it from pin 9 to pin 15 on the ECU.
jimmymig
Mon Jan 14, 2013 2:11 am
thanks rich will give that ago when I finish fitting poly bushes :)
jimmymig
Sun Apr 28, 2013 2:49 pm
Finally got round to looking at my wiring pin 9 to pin 20 was done it is pin 14 i am missing on e36 side! Can i run a wire straight to the ecu from pin 14 e30 plug and if so anybody know pin number on ecu that needs conecting? Thanks jim
jimmymig
Wed May 01, 2013 3:13 pm
sorted :P connected pin 14 on e30 side to pin 9 on e36 side full revs and a happy me
