Engine not sitting on mounts properly and at an angle
Jozi
Post Fri Oct 19, 2012 6:53 pm
Is it normal for the engine to sit at enough of an angle for the gearbox mounts to not sit on the mounting bracket?
I used 2x M5 (I think) rubber mounts and they look to be seated right on the subframe.
Nas80
Post Sat Oct 27, 2012 2:38 am
are you using the wrong engine mounts or worn out mounts?
Jozi
Post Sat Oct 27, 2012 11:25 am
New mounts on the engine and gearbox, engine I used M5's (from memory) and the box is E30 mounts.
Sanchez
Post Sat Oct 27, 2012 11:28 am
Is the blue rope holding it up?
Jozi
Post Sat Oct 27, 2012 11:29 am
No, it was used to lift it in, it's hanging lose between the engine and firewall.
jmc330i
Post Sat Oct 27, 2012 12:48 pm
Any pics of the engine mounts?
From memory, I used the E28 M5 mounts and had to remove the small rubber tang on the bottom of the round mount so the mount could then be turned through 180 degrees. If this wasn't done, the mount will sit slightly out of line with the engine mount - I did fit mine like this first, but noticed the round mount was being squashed on one side, I didn't notice how the gearbox sat as I turned the engine mount round when I noticed, but it may of not let the engine sit down correctly.
James
'91 325i Sport
'93 318i touring 16v
Post Sat Oct 27, 2012 1:45 pm
If it all bolts down OK, I wouldn't worry about it - new mounts can take a while to 'bed in'.
Jozi
Post Sat Oct 27, 2012 2:17 pm
None of it's bolted down yet which might not help. From memory I have the e28 m5 mounts as well, I have the little bit sticking out lined up so it's in the hole or slot on the subframe. I'll get a pic of the mounts later if I get a chance.
Post Sat Oct 27, 2012 3:11 pm
Are the M5 mounts not tapered one way? :?
jmc330i
Post Sat Oct 27, 2012 4:00 pm
Jozi wrote: I have the little bit sticking out lined up so it's in the hole or slot on the subframe. I'll get a pic of the mounts later if I get a chance.
You need to take that little 'bit' off with a grinder, it doesn't sit in the subframe.
If you look at the mount, the two threaded sections are offset from each other. If you try to fit the mount with the little tang in the subframe, it will pull the mount out of shape - I can't think of how to describe it, other than the mount will look like its leaning. It will eventually cause the mount to tear.
With the little tang removed, the mount can be rotated so it sits straight as it should do.
James
'91 325i Sport
jmc330i
Post Sat Oct 27, 2012 4:11 pm
Rav335uk wrote:Are the M5 mounts not tapered one way? :?
As above, the litte rubber tang on the mount makes sure the mount is fitted the correct way for the offset threaded studs when fitted to the M5, but the offset of the studs is wrong for use in the E30, so the the mount needs rotating until the mount holes and studs line up - from memory, once rotated the threaded stud needs to go through the hole not normally used for the mount (I can't remember if its the inner or outer hole).
James
'91 325i Sport
maxfield
Post Sat Oct 27, 2012 5:38 pm
May sound silly but is the gearbox mount bigger one side than the other? Or is that camera angle?
What if you turned that 180 degrees?
jmc330i
Post Sat Oct 27, 2012 5:43 pm
Gearbox mount is taller on one side. Turning it round would make the matter worse.
James
'91 325i Sport
Jozi
Post Sat Oct 27, 2012 7:17 pm
Both my gearbox and engine mounts are the same left/right, prob just the camera angle. I didnt get a chance to look at the engine mounts today, might get to it tomorrow.
jmc330i
Post Sat Oct 27, 2012 7:38 pm
Jozi wrote:I didnt get a chance to look at the engine mounts today, might get to it tomorrow.
The engine mount might not be causing this problem, but if you do have the little tang in the subframe, it will be causing the rubber mount to stress.
James
'91 325i Sport
Jozi
Post Sat Oct 27, 2012 7:41 pm
I'm nearly sure i pointed them tangs so they were either in the hole or in the slot on the subframe.
Does the threaded stud go in the slot or the hole in the subframe?
Post Tue Oct 30, 2012 10:04 pm
Stud goes in the outer slot
