Which gearbox will suit these ratios
darcy
Post Fri Aug 31, 2012 11:40 am
Ho guys I've got a 320se that has had a2.5 m20 fitted in the past. I have got hold of a 328 e36 which I intend to transplant in the next few months. The other day the e30s diff died so I'm looking for a replacement but I need one that will suit the m52b28 engine. The gearboxes I have at my disposal are e30 1.8is and 325. Or the 2.8 that came with the e36.
The LSD ratios I have been offered are 3.64 3.73 3.91.
So I need to know which diff/box will compliment the conversion the best. I believe the ratios are wrong for the e36 box but I'm not sure about the 1.8 and 2.5 box
greggers
Post Fri Aug 31, 2012 12:12 pm
Will it be a track or a road car? Do you do a lot of motorway miles?
darcy
Post Fri Aug 31, 2012 12:25 pm
It's on the road, I'd prefer a lower cruising rpm rather than it screaming, but not that dosile that it won't accelerate
Duke137
Post Fri Aug 31, 2012 12:32 pm
Motorhole
Post Sun Sep 02, 2012 9:31 am
Ratios in both e30 boxes are ok for any of those diffs but only the 318is box will fit at the right angle. If you want to use the e36 box, need 2.93, 3.15, 3.23.
bimanut
Post Sun Sep 02, 2012 4:40 pm
A bog standard m40 box can be used also
Dave_M3
Post Sun Sep 02, 2012 6:29 pm
325 box will fit no problem. Just abit of work on the linkages but only really worth the hassle if you've a Sport box which works very well with a 3.64 or 3.73.
