m50tu Cam sensors
HairyScreech
Post Sun Aug 12, 2012 10:40 pm
Are m50 and m52 crank sensors the same?
I know the plug is different but is the function and output the same?
Barx325i
Post Sun Aug 12, 2012 10:44 pm
check autodata, I have a copy somewhere.. but not installed :(
HairyScreech
Post Sun Aug 12, 2012 11:11 pm
doh, thats what i get for doing two things at once.
CAM sensor, not crank sensor.
good thinking on the auto data, might be in the tech manuals i have as well.
i have a plastic cam sensor from an m52 kicking about so i don't want to buy another one if i can use that.
HairyScreech
Post Mon Aug 13, 2012 9:07 pm
Ok from looking auto data is unreliable and there is conflicting info out there.
my dme is the 3.3.1 for a non ews m50tu (single vanos)
now the crank senor is a normal VR one which is fine to use an e30 one for.
However i am short a cam sensor and happen to have an m52 one.
The cam sensor for the m50tu is hall effect which i am led to believe is for m50tu engines and newer as the m50nv is VR.
Is the m52 sensor still a conventional hall effect? if so it should be fine to use.
Post Mon Aug 13, 2012 9:40 pm
M52 cam sensor is near enough identical to the M50 vanos so yeah, get cracking :D
HairyScreech
Post Mon Aug 13, 2012 9:43 pm
sweet, i have one kicking about so that will save me a bit of cash.
I have started a m20/m50tu ecu thread now if your board boss.
