M52 oil change time which oil?
rich318i
sorry i know this has been asked many many times before but what would you say i should use 5w-30 or 10w-40 full or semi? engines done about 150K and never drinks oil, thank the lord!
All mine get 5W-40 full synthetic.
leeparkes
I tried 5w-30 on my first M52 and it made it a little rattly, 5w-40 in now and its fine (full synth)
rich318i
cool! cheers lads
rich318i
was thinking of using just using triple QX or is there a brand that you would recommend mate? CheersBrianmoooore wrote:All mine get 5W-40 full synthetic.
This is the man to ask - it seems that all synthetics are far from equal: http://www.e30zone.net/modules.php?name ... ic&t=80776
Personally, I normally use Shell Helix Ultra, because I can buy it for about £3.50/litre in France.
LagunaE30
i've used 5w30 in mine and its definetely made it a bit rattley, it had 5w40 in there before this and it was very smooth and the engine was silent.
i'm going back to 5w40
BMW's original recommendations for oil for a M50 only specify a 10W-30 to a maximum air temperature of around +5 degrees Celsius. 5W-30 is only suitable for a maximum air temperature of -5 degrees!
rich318i
i put 5w40 in to it today and sounds lovley
e30-EVN
danthe told me to use 5w 30.!
A 2 door e30 with 8 cylinders, what could be better
e30-EVN
Did an oil change earlier using the oil suggested by Dan and she's great. Doesn't rattle at all... Guess mines a healthy engine as a pose to a baby's rattle
rich318i
i had to have a read up about 5w40 ,50,60 and so on.... is the temps they work at.
i was just a oil is oil person lol
Barx325i
asda have gtx @ £12 at the moment
