Another m52 miss fire
jimmymig
This one is starting to wind me up! Car has a miss fire on idle a little pop every 3-4 sec! It is missing badly for about half a mile then clears runs really nice. But it will cut out pulling up to a stop then run badly again same if I stop the car even for seconds:-( Have checked for air leaks unpluged maf car cuts out unpluged vanos still the same any ideas? Cheers jim
craigieeb
Have you checked the coil packs individually?
M50 Turbo!!!
I shall say no more
Check all the injectors are plugged in/ make sure the rail going to the top of them is all pushed down and they are all clicked in fully
jimmymig
Checked injector last week how do you check coil packs?
Sounds like an air leak to me, ICV working ok?
johnl320
Is it me or does there seem to be a lot of m52s struggling at the moment?
Should of stayed 12 valve
There's a lot out there that need to learn what a code reader is and what it's for!
Code readers dont tell you about the split hose or open port under the inlet manifold though Brian, plenty of those about!
jimmymig
Fault code on vanos thats why its unpluged! its sticking need to change seals:-(will coil show up on diagnostic?
They will if you know how to interpret them. I presume an air leak on the inlet bits would give a lambda sensor out of range type of code.DanThe wrote:Code readers dont tell you about the split hose or open port under the inlet manifold though Brian, plenty of those about!
