Head Inserts - Just Wondering
greggers
Post Tue Oct 04, 2011 10:58 am
Just curiosity more than anything else, has anyone used these http://www.hutsonprecision.co.uk/automo ... -1183.html when doing a head gasket repair job... Would they be a better bet than risking the standard threads, or would you use these if you'd already killed your standard threads???
Jozi
Post Tue Oct 04, 2011 1:36 pm
greggers wrote:Just curiosity more than anything else, has anyone used these http://www.hutsonprecision.co.uk/automo ... -1183.html when doing a head gasket repair job... Would they be a better bet than risking the standard threads, or would you use these if you'd already killed your standard threads???
When you strip the threads
greggers
Post Tue Oct 04, 2011 3:17 pm
Do you think their claim of doubling the strength of the threads sounds plausible?
Post Tue Oct 04, 2011 6:26 pm
It wont double the strength of the ally theads but screwing a bolt into a steel insert is better than screwing into ally. If the head bends it will pull the ally threads regardless of inserts
or no inserts IMO
greggers
Post Tue Oct 04, 2011 7:58 pm
So if you were considering forced induction these could be a worthwhile upgrade.
Perhaps their claim is based on the fact that you are increasing the surface area of the whole thred.
