Clio servo on LHD e30?
Phil123
Post Wed Sep 07, 2011 1:29 pm
Hello,
can someone tell me if the Clio Servo works also on LHD e30 by any chance? Is there a confirmed partnumber for the Clio servo with the adjustable push rod? I try to get a servo with the partnumber 8200 192 612 but not sure if the rod is adjustable :( .
Post Wed Sep 07, 2011 1:35 pm
The servo fits the same way, you need to fabricate something to adjust it up to the pedal. Beardymat did this, it will probably help you to read the whole thread - http://www.e30zone.net/modules.php?name ... c&start=25
Look here for adjusting the rod up to the master cylinder - http://www.e30zone.net/modules.php?name ... sc&start=0
JGTI
Post Thu Sep 08, 2011 1:37 pm
i just unscrewed the bit that goes to the brake pedal and welded it to the clio servo, and had the spacer made to fit the pump.
