m52b28 radiator
jimbob88
just a quick queriy to see if someone can confirm this would be the right radiator for my conversion
i know it has to be from an aircon model and at a glance the standard one is square where as the aircon model has a shorter filler bottle on the side making iot look like it has a corner missing
is this the right rad?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
e30-EVN
I have an e36 328 aircon rad fitted to my car and it looks the same as that. I don't know core sizes ect but your description of the tank is as my rad is
A 2 door e30 with 8 cylinders, what could be better
e30-EVN
No problem mate
e30-EVN
No mate, opposite side
I forgot about the thermo
e30-EVN
It doesn't look to me as though the one in the pic has a thermo switch port unless I'm mistaken.
You need an e36 328 aircon rad, I would have thought the ad title would say that if it was one mate
e30-EVN
Pm danthe, he may know and I'd be supprised if he didn't
Just ask the guy selling the rad, the dimensions are correct though, I notice there is no brand on the rad which says to me its probably a recon, a Nissens is about £100 from ECP
jimbob88
Just a quick bump, think i've managed to find a rad just want to double check
Is this the right rad? Its from a 98 328i it has the shorter expansion bottle and a temp switch on the opposite side
maf260
Here's the rad I have - should look like this:
leeparkes
If it helps, on the left is an E36 328i aircon rad. (click on the pics to make them bigger)
For what its worth the rad on the right is from an E36 318ti with aircon, the only difference between the two is the channels are slightly thinner.
The capacity difference is this. (about 200ml)
Ive been running this rad with an M52 for well over a year now with no drama's at all, the car has aircon too.
So maybe worth a thought if your having trouble finding a 328i rad.
maf260
Not a clue I'm afraid, Jamie - it came with the rad.
Thats an ebay universal fan, fastpartz or something is the sellers name, ive fitted a few and they are ok, not particularly fast but if you get the biggest fan you can fit to the rad you should be ok
leeparkes
These do the job welljimbob88 wrote:I've seen a really good second hand E32 aircon fan in great nick fairly cheap i think i might have a stab at that
nickso
- Location: Go do that voodoo that you do so welllllllll!!
do all of the bmw aircon fans fit the e30? i have somehow managed to destroy my kenlowe fan today and also lose all power to the fuses
options are small as my scrappy has sod all bmw's in it apart from a low spec e34 and another e34 still on the ramps but possibly with an aircon fan as it's a 530i.
'88 e30 328i M52 track bint.
nickso
like i say options are small so the e34 one will be getting bought for a trial anyway.
