Why not to fit the square mounts,,,
- Contact:
Used them for a couple of years on my M50B25, they were fine when fitted to the chromie with the 2.8 but I noticed the drivers side started to crack/craze which I assumed was from the heat being close to the exhaust, so the manifolds were wrapped. The drivers side seemed to deteriorate quickly with the 2.8 (240hp) so when I fitted the alpina after 3,000 miles of running the 2.8 I didnt use it again but the passenger side was still good, ive done about 1,000 miles with it and its now in two pieces
AKG mounts will be going on now...
				craigieeb
Are you going for the polly ones or the Alloy ones?
Wouldnt mind going down the alloy mount route my self,
engine/gearbox/diff
but then the only weak link would be the centre bearing on the prop
engine/gearbox/diff
M50 Turbo!!!  I shall say no more
 I shall say no more
						 I shall say no more
 I shall say no more
A must see for anyone doing the M5x swaps thenDanThe wrote:Used them for a couple of years on my M50B25, they were fine when fitted to the chromie with the 2.8 but I noticed the drivers side started to crack/craze which I assumed was from the heat being close to the exhaust, so the manifolds were wrapped. The drivers side seemed to deteriorate quickly with the 2.8 (240hp) so when I fitted the alpina after 3,000 miles of running the 2.8 I didnt use it again but the passenger side was still good, ive done about 1,000 miles with it and its now in two pieces
				ross_jsy
For anyone who is interested:
http://www.akgmotorsport.com/catalog/ca ... M50%20Swap
Second from the bottom.
