m50 engine-m42 box- 320 prop question-pics ect
e30-EVN
As above ^, I've gone to connect my prop and noticed the centre bearing does not line up with the 2 holes in the car! Had a look at reversing the centre bearing but there is a lip on the other side stopping it from going over the bearing on the prop!
Help please? Ant
Help please? Ant
A 2 door e30 with 8 cylinders, what could be better
Duke137
Wrong prop maybe?
I have a 320 manual prop but someone told me you need a 325 manual prop so I bought one just in case....
Watchin this with interest
e30-EVN
Yes whoever told you that was right ferg!
Just me measured them up and the front half of the 325 prop is slightly shorter than the 320!
I'm going to try that now but cos of my z3 shifter I'm going to remove the large round apnin rather than bend my linkage!
I will get back to you shortly mate
Yep, 325 prop is the way to go with the M42 box dudes. Remove the vibration damper like you plan to Ant.
e30-EVN
All done! Cheers lee, just got it back together now- 325 front half (minus vib damper), e30 centre bearing (as normal), 320 back half.
Time to fit!
Time to fit!
Have those Lambdas turned up yet dude?
e30-EVN
Not yet mate, but I'm expecting them to some time today,
Prop on with combo used above and she moves!!! Buzzin
Duke137
Nice one Ant for the information
e30-EVN
No worries ferg, it defo works mate. I drove it round the block earlier and she's fine. Try and upload the video later
blue30
That's weird, I ran a 320i prop on an M40 box for the best part of a year
Are the M40 boxes that much different to M42 boxes?
Duke137
have you uploaded your pics/vids yet you useless shyte?
e30-EVN
i tried to use my 320 prop as the 325 ones have a big vibration damper that would have got in the way of my linkage ect but it seems the 320 front half is about an inch longer than the 325, which is how much my centre bearing was out by! so i did the above and took off the damper and hooked it up to the back end of 320 and this works great. there must be a slight difference in the boxes even if only an inch mate!That's weird, I ran a 320i prop on an M40 box for the best part of a year Are the M40 boxes that much different to M42 boxes?
e30-EVN
front half of 325 prop minus the vibration damper, tap the bolts out as they are splined in......
this is the whole thing made up from, 325 front (no vib damper), e30 centre bearing (as normal), and 320 back half.........
this is a short teaser of it running...! at this point she had no lambda sensor (reason for moving it to car park), no air filter and just the downpipes......
http://s826.photobucket.com/albums/zz19 ... ABeast.mp4
Duke137
e30-EVN
you like mate? LOL.... laptop dongles are lame!!! thats why its taken so long to get them up. obviously do some more pics when its done, have a wing to sort, exhaust and a few extras to put on but there she is
i love it, she is awsome
rancido64
Just looking to confirm;
currently i have an m40, will be going m50 - Is it worth me going to the trouble of sourcing an m42 box or should i just stick with the m40 box and get a 320 prop to save the messing around with different bits of different props?
craigieeb
http://www.e30zone.net/modules.php?name ... c&t=186658rancido64 wrote:Just looking to confirm;
http://www.e30zone.net/modules.php?name ... c&t=186694
BTW
that 24v looks right at home there e30-dk matey
M50 Turbo!!!
I shall say no more
e30-EVN
If you already have the m40 box and 320 prop use those (if that combo works), but my car started a 320i which I converted to 325 so I had the choice of props. I sourced out the m42 box as I'd been told its the better for handling the torque. Its up to you but decide which box your going to use and then the prop choice is made for you aswel
e30-EVN
Cheers craig
, she does look snug ay
I'm proud of it, she's a different beast now mate LOL.
blue30
As above I used that combo for about a year and 15K miles, the box was farked at the end but then it was farked at the beginning too, lol (i.e. I bought a knackered box)rancido64 wrote:Just looking to confirm;
If yours is a known good box then thats got to be better than some random unknown box off ebay or whatever...
Don't forget to change the spigot bearing in the M50 to suit the smaller input shaft either way
Duke137
Ant, I had a click round on your photo bucket mate. Fookin class.
No wonder your happy with it!
rancido64
Well, my box doesn't crunch or seem to have any other issues tbh, i've driven it daily for over a year since i got it and no problems so i'll stick with thatblue30 wrote:As above I used that combo for about a year and 15K miles, the box was farked at the end but then it was farked at the beginning too, lol (i.e. I bought a knackered box)rancido64 wrote:Just looking to confirm;
rancido64
So i change it for an m20 one, yeah?blue30 wrote: Don't forget to change the spigot bearing in the M50 to suit the smaller input shaft either way
e30-EVN
Yes mate, m20 spiggot has 12mm diameter hole which matches the input shafts of the said boxes. M50-52's have 15mm spiggots.
rancido64
Awesome
my list is slowly coming together, should receive the engine sometime in the next week or two so need to get cracking on the rest of the bits now
e30-EVN
Thas the way mate, get it done man
joshce
this threads helped me loads, doing the same conversion at the moment. cheers!
Just wondering is there any noticable diff without the vibration damper removed?
e30-EVN
No worries,
No noticable difference with the damper removed! Reason I took it off is clearance between the prop and my linkage (which I didn't want to bend)
