cooling fan
town325i
what fans is everyone using on there m50 conversion's please im just trying to see what is in the scrapy down the road
Cook318IS
e36 328i fan... only just fits. I mean literally you can't get a fag paper between the fan and the chassis! its 16" iirc.
bimanut
I remember reading that some one had used a viscous and used a strap on the back of the gbox.willnz wrote:e34 a/c fan plus i used the viscous fan on mine as well
Was this you?
If so do you have any pics of how you did it?
I like the idea of using the viscous as well.
town325i
how the hell did you get a viscous fan in there the ones ive seen have hardly any room between the rad and front of the engine
RichIS
ive totaly got rid of the viscous and am going to be using a electric fan on the front of the rad off wat ? i dont know yet ill see wat the scrappie brings lol
Injections nice....but I'd rather be blown ;)
town325i
would someting like this be any good ?
http://cgi.ebay.co.uk/14-UNIVERSAL-RADI ... 3359a599bf
bimanut
Iknow it wouldnt be easy but some pics of the strap,rubber mounts and viscous fan would be greatwillnz wrote:Yes, I did that. I used the standard e36 328i radiator and a viscous fan blade that was quite thin (dont know what BMW I got it off, have wrecked too many to remember). I also had to trim the ends of the fan blade to allow it to clear the lhs radiator tank. if you go to my post http://www.e30zone.net/modules.php?name ... highlight= there are a couple of pics of the engine bay.bimanut wrote:I remember reading that some one had used a viscous and used a strap on the back of the gbox.willnz wrote:e34 a/c fan plus i used the viscous fan on mine as well
Was this you?
Fan is close to the radiator core (probably 20mm) so I anchored the gearbox using a woven earth strap to the chassis so it wouldnt be able to move foward under sudden braking. The woven strap also wouldnt transfer vibrations through to the body like a solid mount would.
Motor is mounted on standard e36 engine mounting arms onto e28 M5/535 rubber mounts.
if you want better details i can take some close-up pics.
That looks a bit sh1t TBH, E36 fan works well, keep it BMW and I will sort you a wiring loom to run the twin speedtown325i wrote:would someting like this be any good ?
town325i
sounds like a good deal to me Dan
Cook318IS
Dan, i dont suppose you know what pin is what on a three pin 80/88 degree sensor?DanThe wrote:That looks a bit sh1t TBH, E36 fan works well, keep it BMW and I will sort you a wiring loom to run the twin speedtown325i wrote:would someting like this be any good ?
town325i
You have to fit these with brackets town, the E36 or E34 will screw straight into the front end, give me a shout when you finish work this week and I will show you round the track slag
town325i
ok sound i will be about on saturday if thats fine with youDanThe wrote:You have to fit these with brackets town, the E36 or E34 will screw straight into the front end, give me a shout when you finish work this week and I will show you round the track slag
booomer
I'm after an electric fan setup too and was wondering if there is a plug and play ish bmw offering. I suppose the e36 pusher fan is the one to go for but what would i do in terms of plugging it in and as far as mounting it would it mount to my e34 radiator ok?
Plug and play would be an E30 aircon electric fan, complete with loom to the fusebox.
booomer
Too late, just bought a spal pusher fan so that will be going in soon!
