M52 to M50 swap - ECU Difference
e30_singh
Post Wed Feb 17, 2010 8:48 pm
If I used a M50 engine in an E36 328i, what missions am I looking at when it comes down to wiring harness and ECU etc.
The E36 has got a good gearbox and clutch but the engine is blown so I am planning to use a M50 I have kicking about.
Any help would be great.
jimmymig
Post Fri Feb 19, 2010 8:13 pm
you will need engine harness and ecu too match.my bro has chipped ecu if u need one.goodluck :P
Dave_M3
Post Sat Feb 20, 2010 1:38 am
Your going the wrong way!!!
S50 is the only way forward from a blown M52 :D
