Good work
Do you need to try and seal it against the bonnet? You could make a complete enclosure around the filter.
Here's my first attempt, the finished one looked the same but with rear enclosed similar to yours.
The enclosure clipped onto existing holes for the plastic headlight backplate and it curved around the rad etc right down to the chassis rail where two little tabs held it firm.
