has any one put a s50 oil filter housing on a m52 engine and had issues with the vanos oil pipe..
the banjo bolt dosent screw into the filter housing as its too big..
any idears?
cheers
ps i have fitted the housing to put a oil cooler on the engine
s50 oil filter housing on m52 vanos oil pipe fitment
- Contact:
Open it up to the correct thread, M14Sx279 wrote:has any one put a s50 oil filter housing on a m52 engine and had issues with the vanos oil pipe..
any idears?
cheers
I had the same issue. You need to open it up to the correct thread. I also needed a M3 power steering pump which also needed a little engineering to get the pipes to fit. It definitely wasn't the straight forward swap I was told, but now fitted it does a good job of keeping the oil temp under control.
Rallyprep_UK
- formerly Driftnething
- Contact:
I have a batch of conversion banjo bolts.
Makes life easy if you are not comfortable modding the housing...
