s50 oil filter housing on m52 vanos oil pipe fitment
Sx279
Fri Mar 07, 2014 10:50 pm
has any one put a s50 oil filter housing on a m52 engine and had issues with the vanos oil pipe..
the banjo bolt dosent screw into the filter housing as its too big..
any idears?
cheers
ps i have fitted the housing to put a oil cooler on the engine
rich318i
Fri Mar 07, 2014 10:54 pm
you need the adaptor, stepped banjo
Sat Mar 08, 2014 10:12 am
Sx279 wrote:has any one put a s50 oil filter housing on a m52 engine and had issues with the vanos oil pipe..
any idears?
cheers
Open it up to the correct thread, M14
maf260
Sat Mar 08, 2014 11:21 am
I had the same issue. You need to open it up to the correct thread. I also needed a M3 power steering pump which also needed a little engineering to get the pipes to fit. It definitely wasn't the straight forward swap I was told, but now fitted it does a good job of keeping the oil temp under control.
Sx279
Thu Mar 20, 2014 11:23 pm
all sorted cheers people i made a new pipe with an fittings and braided hose..
i havent got pas pump on my e30 dont feel the need for it and as irs a track car less weight haha...
thanks again
rich318i
Thu Mar 20, 2014 11:26 pm
only reason for the pump is for the OEM style
Rallyprep_UK
formerly Driftnething
Mon Mar 24, 2014 4:39 pm
I have a batch of conversion banjo bolts.
Makes life easy if you are not comfortable modding the housing...
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
