m50b25 block question
vladv
Sat Jul 23, 2011 8:07 am
I bought m50b25 engine and m54b30 pistons for stroke.
Block checking shows that it was honed to second repair (D=84.5mm).
What do you advice: installing block sleeve or changing block?
thnx.
Sat Jul 23, 2011 8:44 am
Fitting those pistons to your engine will lower compression, if you are planning an engine build then you want a standard spec block
vladv
Sat Jul 23, 2011 9:52 am
DanThe wrote:Fitting those pistons to your engine will lower compression, if you are planning an engine build then you want a standard spec block
yes, but motorist advices to install cast-iron sleeve and hone them to piston size.
Also whatever another used block has own working defect.
