E30 M30 conversion Help
LadyLeigh
Started my conversion, engine is now in after purchasing the mounts from lee.
Tried to fire up this evening, it started. Went to restart it and nothing.
Doesn't seem to have a spark or fuel.
Running M30 engine Loom and ECU.
Any input would be great.
mcbonio
Is the ground strap on the engine connected?
jimbom30cab
- Tech 1 freak
DME and fuel relays tight ?
Battery terminals done up tight ?
- E30 Zone Meets/Events Team
DME relay?
LadyLeigh
Ummmmm first conversion I have done, ground strap? Earth?
Jump pack was straight to engine?
LadyLeigh
Would anyone local enough to Reading be able to do it? If so at what cost?
Hold on, deep breaths, and ..........................................relax.LadyLeigh wrote:Would anyone local enough to Reading be able to do it? If so at what cost?
Now, check fuses first.
Also, what engine was in the car before the swap?
LadyLeigh
M20 engine lol 325.
It's giving me a headache plus this stuff isn't my fav
Did you swap over the wires at the C101 plug?
jimbom30cab
- Tech 1 freak
give me a call tomorrow during the day
07525 39111seven
07525 39111seven
leeparkes
Engine should still run without swapping the wires at the c101
If you have no spark or fuel try the white DME relay first, your M20 one will fit.
Earth strap is a thick wire that goes from the engine block and bolts to a chassis rail.
Rav335uk wrote:DME relay?
Forgot to ask, you don't mention, is it cranking over?
leeparkes
Rav335uk wrote:Rav335uk wrote:DME relay?
jimbom30cab
- Tech 1 freak
lovin' the M30 commardary
LadyLeigh
Where is the DME located?leeparkes wrote:Engine should still run without swapping the wires at the c101
It started up without changing over the wires on the C101.
LadyLeigh
Thank you, will give you a bell today.jimbom30cab wrote:give me a call tomorrow during the day
07525 39111seven
jimbom30cab
- Tech 1 freak
have you got it running then? pleased with it mate?
bmwsean
funnily enough years ago I had the same problem when I did the m30 swap, after an hour of head scratching I took the engine loom of an replaced it with the original M20 one, fired straight up, must be something really simple
jimbom30cab
- Tech 1 freak
Did the m20 engine loom fit ok ?
