m30b35 correct emissions.
mcbonio
Post Thu Nov 22, 2012 8:53 am
After finding out my PO had wound the cO2 screw in all the way I adjusted it and got my car running good.
I want to set the AFM correctly with an exhaust analyzer that my mate is going to lend me for the afternoon so it will pass emissions tests. But I need to know what is the correct level of c02 the m30 should be putting out?
Anyone know or can lend some experience on this?
Bristol_Jer
Post Thu Nov 22, 2012 5:51 pm
Bristol_Jer
Post Thu Nov 22, 2012 5:52 pm
That's from my Autodata CD :)
mcbonio
Post Thu Nov 22, 2012 7:34 pm
Cheers Jer.!
So what do I do with a twin tail pipe and a gas sniffer with 1 probe? Do I measure each tail pipe then add the values together?
Bristol_Jer
Post Thu Nov 22, 2012 8:02 pm
Are the pipes seperate all the way through the system?
mcbonio
Post Thu Nov 22, 2012 8:24 pm
Yup, m30 headers going into a 325i exhaust system. No X pipe.!
Bristol_Jer
Post Thu Nov 22, 2012 8:30 pm
Same set up as I have on mine, I didn't realise the pipes were kept seperate inside the boxes, I just assumed they were 2 perforated pipes inside each box so the gases mixed!
mcbonio
Post Thu Nov 22, 2012 8:34 pm
So how do you accurately test a twin pipe then?
zaust
Zone day release
Post Fri Nov 23, 2012 6:40 pm
With a y tube connected to the probe.
If you can get a reading of 1 30 ish it will be fine. I run mine rich due to n2o input and the limit for these age cars is very high so don't worry about mot.
M30 Tech 1 Touring on gas.
mcbonio
Post Fri Nov 23, 2012 7:21 pm
Cheers Marc,
I still want to tune up my AFM, it's 1000 times smoother at idle now I wound the screw out but still not perfect. I get bugged by little things which is not great when owning an e30 ) :cry:
So a healthy cO2 mix at idle should read around 1.3 you say ?
Mikey_Boy
Post Fri Nov 23, 2012 7:40 pm
mcbonio wrote:Yup, m30 headers going into a 325i exhaust system. No X pipe.!
Having an X pipe will really drag the torque up if its in the right place... Worth the investment! :thumb:
mcbonio
Post Fri Nov 23, 2012 7:55 pm
I got one of speedtouch's chips in, It's already very quick.!
Mikey_Boy
Post Fri Nov 23, 2012 8:23 pm
On another topic - has your avatar changed recently? Wasn't yours something freaky with sausages?
Ramdom I know... :thumb:
mcbonio
Post Fri Nov 23, 2012 8:45 pm
Lol, yeah was hotdog sausages being thrown into a womans face. :eek:
Where abouts in Cheshire are you Mikey?
zaust
Zone day release
Post Fri Nov 23, 2012 9:35 pm
mcbonio wrote:Cheers Marc,
yep
Mikey_Boy
Post Sat Nov 24, 2012 9:25 am
mcbonio wrote:Lol, yeah was hotdog sausages being thrown into a womans face. :eek:
That Avatar made me laugh my bollox off! I am near Tarporley fella - whereabouts are you??
jmc330i
Post Sat Nov 24, 2012 10:03 am
Bristol_Jer wrote:Same set up as I have on mine, I didn't realise the pipes were kept seperate inside the boxes, I just assumed they were 2 perforated pipes inside each box so the gases mixed!
If its a standard 325i exhaust, I've never cut open a centre box, but the backbox is separated into 3 sections along its length. Both pipes pass through each section in a complicated mess of pipes to keep the noise low, and the gas from each pipe does mix in each section of the box through perforated pipes.
My 325i was gas tested with a single probe in one tailpipe and when the MOT place got a new gas tester, a single probe in a large 'cup' type collector that covered both tailpipes. It never failed an emissions test and the results didn't really vary between tests.
James
'91 325i Sport
'93 318i touring 16v
mcbonio
Post Sat Nov 24, 2012 7:53 pm
Tarporley? You country bumpkin Mikey.! :P Bet you have some nice country roads to thrash your m30 along.!
I'm in central Liverpool. :rock:
Mikey_Boy
Post Sat Nov 24, 2012 10:21 pm
I am indeed a carrot cruncher............! :thumb:
I am also now running 4 cylinders instead of 6 - S14 install!!
I miss the sausages.... 8O
mcbonio
Post Sat Nov 24, 2012 11:30 pm
The sausages?! 8O
Yeah don't see the point in the s14 engine thb, very expensive engine that doesn't produce that much power... :? sorry.!
Mikey_Boy
Post Sun Nov 25, 2012 6:07 pm
It was a challenge.....! :thumb:
Horses for courses - one man's meat is anothers poison and all that.
And by fook it was expensive - you are right there... But... It will make the right noise - they do make good power though when well set up.
Sausage face woman - I miss that! :thumb:
zaust
Zone day release
Post Sun Nov 25, 2012 7:26 pm
You can't compare an s14 and an m30. The s14 is such a good power base and can be driven so hard it will always be the thrash engine of choice. The m30 will take a kicking and make good power but just not In the same way.
mcbonio
Post Sun Nov 25, 2012 8:17 pm
I can agree to that Marc, I guess the S14 is gearing towards racing and can take be driven on the limit all the time, where as a standard m30 isn't setup that way.!
They do scream I must say. :twisted:
Mikey_Boy
Post Sun Nov 25, 2012 8:30 pm
^^^^^ and that's why I got it - track day car screamer!!! :twisted:
