ECU and Chip details
gooseygander110
Post Sun May 06, 2012 2:46 pm
Hi Guys, hoping some of you might be able to help......... Have recently bought a M30 converted E30 2.0 and am trying to iron out some ...er interesting faults !!! I managed to trace the crap running to loads of air leaks (now sorted) and a TPS and have set that up as per Bentley. Car now idles fine but as rich as hell. No apparant running faults just rich......about 6-7% at idle and only comes down a tad with throttle. Unfortunately I don't know the history of the car but got in touch with the guy who built most of it for someone. I think That someone then ran out of money and threw the rest together and it shows !! My question is this....... can anyone identify this chip and year of ECU? I am wandering if it needs a lambda sensor ? Does anyone know if this ECU/chip combo needs a lambda ?
Thanks in advance. Gus
Bristol_Jer
Post Sun May 06, 2012 2:55 pm
Might be worth sending a PM to Speedtouch, sure he would be able to tell
gooseygander110
Post Sun May 06, 2012 3:14 pm
Thanks mate...... I guessed as much and already have :idea: I was told it came from a Hartge H5 with correct cam and a "chip" .It does go like stink and revswell past red line so if I can just get this rich running sorted .....on to the next stage :)
zaust
Zone day release
Post Sun May 06, 2012 7:05 pm
Would just get a probe stuck up its pipe and adjust the afm accordingly for now.
M30 Tech 1 Touring on gas.
gooseygander110
Post Sun May 06, 2012 9:13 pm
afm is not adjusting :? It checks out on all other tests ......voltage etc .........flappy bit registers even voltage on opening etc........ mind you ........i have put in the original blue sensor.......i ordered another from Chandlers as a matter of course........totally different part no........ will check the output gas tomorrow....... after i finish the kenlowe fan switch thingy.
........ gonna start a new thread with regards to general ....progress.......hopefully some of you guys might be interested :mad:
Post Sun May 06, 2012 9:33 pm
The chip label would suggest it is a Brodie Brittain Racing (BBR) chip, dated 26/8/1994.
It shouldn't need a lambda sensor, but it could probably be optionally fitted, since the 179 ECU is a later Motronic 1.3.
gooseygander110
Post Mon May 07, 2012 9:24 am
Hey Maurice, really apreiciate your input...... any ideas on why the Co is so high 6-7% :? engine running fine ......have sorted TPS and set up, no air leaks, AFM checks out but doesn't adjust on the screw ? I was wandering whether being the laster ECU it needs the input of a Lambda and the monkeys who "finished" it off just left it off ? .......Hmmm spose it should have a sensor plug somewhere then ? :idea: all the best Gus
Post Mon May 07, 2012 12:38 pm
Have you tried the correct ECU initialisation procedure? On first fitting it, or on reconnecting the battery, you should let the engine idle for at least 10 minutes to enable base idle settings to be learnt, then switch off, then take it for a drive throughout the rev range.
So, it may be worth disconnecting either the ECU or battery and leaving it disconnected for at least an hour to reset it, then try the above.
The Lambda plug, if fitted, is normally in the engine bay, near the bulkhead above the exhaust manifold.
gooseygander110
Post Tue May 08, 2012 9:01 pm
Thanks Maurice,
will give that a go ASAP.
really apprieciate your advice :D
