Just need the time to do it now.
Oh no... all done and running now.
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
Mayo on the oil cap and a little on the top of the dip stick. Looks like a head gasket as I have already had the cover off and run it up, there's no signs of cracks or jets of water.
- E30 Zone Meets/Events Team
YOu'll sort that out no problems Marc.
Has the car been standing?? could be moisture, seen this on Clio's
zaust
- Zone day release
You still got your spare Head???
zaust
- Zone day release
I knew you'd need it later,
zaust
- Zone day release
leeparkes
Bad news! but in a way good news if you have a spare head.
zaust
- Zone day release
zaust
- Zone day release
leeparkes
Im sure earlier e28 engines are higher comp
zaust
- Zone day release
B34 has a spikey cam too
I'd wait until warmer weather - it may disappear then, of it's own accord.
zaust
- Zone day release
E28 lumps , if you get one for the right price, aren't too bad mark, but many are past their own sell by dates, and ideally need a few £'s thrown at them.
E34 are better, peado pete has one if you do get stuck looking for a good one.
zaust
- Zone day release
No. didn't ask him
zaust
- Zone day release
zaust
- Zone day release
Well put pressure in each cylinder and got good results. So not head gasket. Pressurized the water system and with two people searching the little dribble was found. I took a pic will post later. So as its a cracked head I can order a head set and get on with changing it with the spare head.
So M30 heads crack as well? I thought this was an M20 thing.
zaust
- Zone day release
All 12v BMW heads have been known to do so. And normally around 5 or 6. Mines gone on 5. Its a shame as the rings and valve seats are letting very little pressure through on 2 & 3 and the rest are fine. Will put it down to using the nos to much and stressing it before its time.
I thought the heads were stronger on the M30, taking about 400hp without any failings
zaust
- Zone day release
zaust
- Zone day release
So, what was it then???
And clean the front end of the engine too
zaust
- Zone day release
Up and running by the weekend then??
You skimming the head Marc?
Like Gareths?
Like Gareths?
zaust
- Zone day release
leeparkes
Lift it into pos 3 while your there.
zaust
- Zone day release
zaust
- Zone day release
zaust
- Zone day release
Done yet Marc??
And pm'd mate.
And pm'd mate.
