if i use a 328i manual prop , do i use all of it or is it a half e30 e36? also is any other e36 prop the same length as a 328i manual? i have a e24 m30 out of a auto ! the flywheel is single mass i think ! can i use it or does it have to be a manual flywheel?
thanks guys just chasing a few final bits
PROP QUESTION fly question
E30SPORTMAD
you need a manual flywheel can't use the auto back plate
leeparkes
Im sure you use the whole prop, not 100% sure though.
Bristol_Jer
With an e34 engine and manual box, you use the whole e36 328i prop, thats what I've done on mine and it fits perfectly
Just read again, are you using an auto gearbox on your conversion?
k20trew
thanks guys iam using a e34 manual box and e34 motor but i also have a e24 m30 motor off a auto
so i have 2 looms 2 ecu's e34 rad and e24 rad < i belive is the same dimesions as a e28
just need mounts and a prop [lee be in touch after xmas]
can i use my 318is gear linkage or do i need a m20 linkage ?
Bristol_Jer
Not sure on 318 linkage, I had a 320 linkage on my car and had to swap it for a 325 linkage to make it all fit, so if a 318is linkage is the same as a 325 then I guess it will be ok!
leeparkes
Iirc 318is linkage is longer, 325i is what you need.
johnl320
I am using an e24 rad, fits nicelyk20trew wrote:thanks guys iam using a e34 manual box and e34 motor but i also have a e24 m30 motor off a auto
