Starter Motor Connection?
Post Tue Oct 18, 2011 9:26 pm
Been a while since I last posted properly :P
Anyway, one last thing left is power to the starter motor. On my conversion, I don't seem to have a power lead going to the starter motor? There is a cable going between the starter motor and the alternator.
Has anyone got pics of how their's is connected up?
TIA
Post Wed Oct 19, 2011 8:47 pm
No-one?
Bristol_Jer
Post Wed Oct 19, 2011 8:50 pm
Straight from battery positive to same terminal on starter as the one going to the alternator, or if battery in boot the straight from the +ve terminal on the bulkhead. Thats how I did mine anyway! :)
Post Wed Oct 19, 2011 8:59 pm
Is that using a separate cable/lead or was it one coming off the main loom (C101 plug loom)?
Barx325i
Post Wed Oct 19, 2011 9:01 pm
8) hey up Imy
leeparkes
Post Wed Oct 19, 2011 11:17 pm
ImysE30 wrote:Is that using a separate cable/lead or was it one coming off the main loom (C101 plug loom)?
Its a thick seperate wire Imy (as thick as the one that comes off the battery, about 10mm thick) iirc standard E30 one is long enough.
I think its number 1 in this link.
http://bmwfans.info/parts/catalog/E30/2 ... ring_sets/
Post Wed Oct 19, 2011 11:21 pm
Looks like it's NLA. I'll have to try and get the one off the other cabby and hope it fits :)
leeparkes
Post Wed Oct 19, 2011 11:35 pm
One off most BMW's will work if its long enough and have the right connections, somethings ringing a bell about using an E34/32 as its slightly longer than E30, but im sure you can use the E30 one without a problem.
Bristol_Jer
Post Thu Oct 20, 2011 6:58 pm
Yep I used my m20 e30 one and it was fine
Post Thu Oct 20, 2011 9:05 pm
Cheer's chaps, another thing ticked off the list, not long left now 8)
