just another m30 swap
shedrool83
Post Mon Nov 30, 2009 11:32 am
At the moment i'm just collecting all the bits and bob needed from the donor (e34 535 sport).
So far i have .
engine, box and ecu
window wash bottle
exhaust downpipe
air con fan
throttle cable
header tank(can i use this ?)
Parts i have on order or will be ordering
M30 engine mounts from beefy
inlet manifold gaskets
exhaust manifold gaskets
exhaust manifold springs and nuts
tb gasket
gear shft seal(using the e30 flange)
rocker cover gasket
sump gasket
pas belt
fan belt
waterpump
chain tensioner
manual e28 535 rad
The engine mounts on the car are new rs2000 burton ones and it also has new gearbox mounts
Have i missed anything?
The donor was also fitted with a multi point lpg kit that i will fit at somepoint but the may thing is to get it in and usable first .
nickso
Post Mon Nov 30, 2009 11:59 am
jake, just use the e30 expansion bottle in its current position. i cant remember what the e34 washer bottle looks like but i doubt it fits. if you use the standard e34 airbox your e30 washer bottle wont fit either. i used a bottle from a nissan micra tie wrapped to the e30 airbox bracket...never got round to making a bracket for it :)
easy to see both sides here.
'88 e30 328i M52 track bint.
shedrool83
Post Mon Nov 30, 2009 12:13 pm
The header tank was just an idea Nick.
I'll be using the washer bottle from the e34 as leeparks has done,it fits in nicely beside the e34 airbox.
nickso
Post Mon Nov 30, 2009 12:30 pm
hmm had i known that i would have binned the micra effort lol.
zaust
Zone day release
Post Mon Nov 30, 2009 12:53 pm
If you can get or have a batt relocation kit, then put a early header tank where the batt used to be. More coolant in the system and much less likley to suffer from pressure problem's. I can't get my e34 washer bottle to fit so will be fitting a small one from demon tweek's.
M30 Tech 1 Touring on gas.
shedrool83
Post Mon Nov 30, 2009 1:02 pm
zaust wrote:If you can get or have a batt relocation kit, then put a early header tank where the batt used to be. More coolant in the system and much less likley to suffer from pressure problem's. I can't get my e34 washer bottle to fit so will be fitting a small one from demon tweek's.
Sure you have to cut a bit off the washer bottle to get it to fit.(more than likely did that)
These turned up 2 mins ago :D
nickso
Post Mon Nov 30, 2009 1:17 pm
tidy, fitting the engine this afternoon then? :)
shedrool83
Post Mon Nov 30, 2009 3:02 pm
nickso wrote:tidy, fitting the engine this afternoon then? :)
I wish mate.lol
I need to get the lump ready first,and i aint in to much of a hurry tbh.
nickso
Post Mon Nov 30, 2009 4:25 pm
I wish mate.lol
join the club......ive only just managed to post my tax refund for my donor car.....might even open its bonnet next month. :P
shedrool83
Post Mon Nov 30, 2009 4:37 pm
Should be a good range of engine conversions at the meets anyway with you going m52 gaz going m50 (for now)and my going m30.Plus daves turbo when its done.
nickso
Post Mon Nov 30, 2009 5:31 pm
shedrool83 wrote:Should be a good range of engine conversions at the meets anyway with you going m52 gaz going m50 (for now)and my going m30.Plus daves turbo when its done.
wouldnt bet on me or dave being finished any time soon. :P
Post Mon Nov 30, 2009 5:41 pm
E34 washer bottle does fit, i have one in my M30 engine bay.
It locates nicely down the side of the OEM air box.
I've done it as passed on the ifo to Leeparkes on here, and he's got one in his M30.
All you have to do it grind of the locating bit of plastic on the bottom of the washer bottle.
HTH's :P
shedrool83
Post Mon Nov 30, 2009 5:52 pm
Rav335uk wrote:E34 washer bottle does fit, i have one in my M30 engine bay.
HTH's :P
Cheers Rav i know i read it somewhere.
It looks good to :D
Has anyone used the e34 header tank ?
leeparkes
Post Mon Nov 30, 2009 6:16 pm
Whoop Whoop! nice to see a new M30 thread.
Best of luck with it :thumb:
HTH's :P
Make sure you dont cut too much off the lug on the washer bottle as i did :o: and it does fit nice and snug by the side of the air box
As for the E34 expansion bottle it can be used,MJJ_ZX6RR is using one.
shedrool83
Post Mon Nov 30, 2009 6:44 pm
Just had a look at MJJ_ZX6RR's bay and i like the header up there.
I do think it may get in the way of a strut brace tho if i decide to put one on.
Also notice he has the ecu's(engine and abs i take it) sitting on the battery tray.
Can the engine ecu go back under the steering wheel without any issues?
leeparkes
Post Mon Nov 30, 2009 6:51 pm
shedrool83 wrote:Can the engine ecu go back under the steering wheel without any issues?
Its a bit of a stretch but it does go under the dash but it rotates 180 degree.
you will see when you get there.
Post Mon Nov 30, 2009 6:54 pm
His ECU's are there because his car is an auto.
Yours will fit in the origional place under the steering , but you will have to turn it 180 degrees as the loom is just short.Keep your origional header where it is, or no strut brace will fit.
shedrool83
Post Mon Nov 30, 2009 7:57 pm
Yeah seem the sensible option to use the m20 header.
Good news on the ecu as my battery is there with it being a touring.
Had to give them a paint aleast its start :D
gareth
Post Tue Dec 01, 2009 12:21 am
more M30 powered E30's :D happy days! :D
if you decide not to use the sequential LPG kit, let me know, i may be tempted to have it off you if i have the money at the time. winkeye
shedrool83
Post Tue Dec 01, 2009 7:37 am
gareth wrote:more M30 powered E30's :D happy days! :D
I think the fuel cost of the first run i take it on when finished will make me want to get the lpg on asap lol
gareth
Post Tue Dec 01, 2009 11:44 pm
i concur :D
BadDave
Post Wed Dec 02, 2009 8:20 pm
Dunno what your trying to imply there Nick
But your probably right.
Bespoke specials always take a while longer to get built winkeye
nickso
Post Wed Dec 02, 2009 9:02 pm
lol. neither of us are going to set the world alight in the quick conversion stakes, certainly not at this time of year anyway.
gcs325i
Post Sat Dec 05, 2009 10:27 am
Looking at Nicks engine bay I think we should use the e34 header tank leaving room for the LPG vaporizers and solenoids where the e30's header tank would go. I'm looking forward to the first test drive of this car, should be rather lively :D
gareth
Post Sat Dec 05, 2009 10:35 am
my LPG vap sits under the servo. awkward to get to but there's plenty of room down here
gcs325i
Post Sat Dec 05, 2009 10:48 am
The one off the donor is a big fecker, it has 2 vap's? To be honest the only bit of this conversion that concerns me is figuring out the LPG as the tube that installed it must have wrapped the wiring around every tube, hose and mounting bracket before soldering the connections up, meaning we had to cut more than a few wire's to remove it. Should only add a day or two to the build hopefully.
gareth
Post Sat Dec 05, 2009 10:55 am
ooh, that's be fun to fit in then! 8O
there's a lot of into on LPG setups out there but chances are brianmooooooooooooooooore will be able to tell you everythng you know off the top of his head as usual :D
you may also want to ask for help re the kit on here: http://www.lpgforum.co.uk/
shedrool83
Post Sat Dec 05, 2009 11:34 am
gcs325i wrote:The one off the donor is a big fecker, it has 2 vap's? To be honest the only bit of this conversion that concerns me is figuring out the LPG as the tube that installed it must have wrapped the wiring around every tube, hose and mounting bracket before soldering the connections up, meaning we had to cut more than a few wire's to remove it. Should only add a day or two to the build hopefully.
It will be a challenge to fit i reckon ,but im sure we will figure it out mate with both of us having gas qualification(or you'd think so).
You might be right about the header tank to free up a bit of space at that side for the lpg setup.would like a strut brace up front so might need to do a few measurements.
shedrool83
Post Tue Dec 15, 2009 7:40 pm
Had a spare hour tonight ,so thought i'd attempt the fitting of the E34 washer bottle.
I have the wash wipe on the headlights which were only there for decoration and i had to do a bit of butchering to the motor so i can still have the wipers and fit the washer bottle in.
I also had to cut the headlight cover as i didnt wont to loss that either.
Still to sort out a better way of securing the bottle but i haave an idea for that.
gareth
Post Tue Dec 15, 2009 11:29 pm
what airbox are you using?
if you use the E32/4 one, it should just about squeeze in but your coil will have to move to make way.
then you can poke the cold air feed through a new trimmed hole in the headlight cover - if there's anything left of it :D
shedrool83
Post Wed Dec 16, 2009 6:39 am
Using the E34 airbox your right there isnt going to be much left of the cover once thats in .
BMWLOVE100
Post Tue Feb 09, 2010 5:20 pm
look like a good job for me
Post Tue Feb 09, 2010 5:38 pm
The airbox will sqeeze in no problem, i have it on mine, and lee too.
Did you cut the lug of the bottom of the washer bottle as it helps it sit down abit more.
If you haven't, be careful not to cut too much or it'll start to leak.
leeparkes
Post Tue Feb 09, 2010 5:49 pm
shedrool83 wrote:I have the wash wipe on the headlights which were only there for decoration and i had to do a bit of butchering to the motor so i can still have the wipers and fit the washer bottle in.
I re-fitted my headlight wash wipe system a couple of days ago and found out my E34 bottle no longer fits there :(
Sure ive read somewhere a vitara bottle works in the battery tray
gareth
Post Wed Feb 10, 2010 1:12 am
that may have been me. well, i have a vitara (iirc, it was 'some' 4x4 thing on top of a pile of scrap cars!) washer bottle, on an adaptor plate that mounts it to the 325i AFM bracket
