M30 rockerarm adjustment
Driftben
Post Wed Oct 21, 2009 9:57 am
Hi all
iv been trying to find the tappet clearances but haven't had any luck on the search and I haven't got my haynes manual with me?
Does anyone know the clearances when cold?
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
leeparkes
Post Wed Oct 21, 2009 3:23 pm
0.30mm
Driftben
Post Wed Oct 21, 2009 4:52 pm
Thankyou kindly ;)
6pot wilwoods front
4pot Porsche rear
chris_335
Post Sun Nov 29, 2009 12:52 pm
it aint eva 0.30mm thats huge
gareth
Post Sun Nov 29, 2009 1:09 pm
chris_335 wrote:it aint eva 0.30mm thats huge
cold 0.30mm
hot 0.35mm
unless you want to burn the valves out or something? :?
chris_335
Post Sun Nov 29, 2009 1:12 pm
realy thats a huge gap
gareth
Post Sun Nov 29, 2009 1:23 pm
it's huge valve! :)
mine is set to that and it's lovely and quiet
chris_335
Post Sun Nov 29, 2009 1:25 pm
Yer True Well I Have Bin Doingine So Thankyou kindly ;)
chris_335
Post Mon Nov 30, 2009 10:00 pm
i think my cam is worn by about 1mm at the max. HELP
gareth
Post Mon Nov 30, 2009 11:23 pm
ouch! 8O that'll be either blocked spaybay or the banjo bolts for it working loose then
new cam time i guess. time for an upgrade? winkeye
chris_335
Post Mon Nov 30, 2009 11:31 pm
yer a upgrade sounds good. but do i need to adjust the arm to fit the worn cam
gareth
Post Mon Nov 30, 2009 11:40 pm
if it's worn on the lobes, no amount of adjustment will help it.
what does the wear look like, can you get a pic or describe it?
chris_335
Post Mon Nov 30, 2009 11:43 pm
well it feels like a very small lip on the lobe but never bin to sur when i say small i mean small very very small less than the 1mm i put
gareth
Post Mon Nov 30, 2009 11:47 pm
when they wear, there will be a step where only part of the cam runs on the follower. if there is visible wear, it's technically done for and has worn through the case hardening layer (it's like a hard shell on the metal) however, at this stage, it will probably not be too bad, just keep an eye on it.
the worse rhe wear gets, the more of an impact loading it will put on the followers and this will in time lead to breakage
where did the 1mm come from? is that the valve gap you have now or something?
chris_335
Post Mon Nov 30, 2009 11:59 pm
k thanks for the info wil keep a eye on it. want a full head rebuild soon with big cam.
and the 1mm was just a rought quick gess
Driftben
Post Wed Dec 02, 2009 10:44 am
I had about a 1mm indent in the cam lobe when I snapped a rocker. Wouldn't bother buying a new cam if your going to put the original lifters in.
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Post Fri Dec 04, 2009 1:18 am
I run my clearences at 0.26mm cold and I've had no problems yet.
Driftben
Post Fri Dec 04, 2009 7:19 am
Does it sound tickery martin?
6pot wilwoods front
4pot Porsche rear
chris_335
Post Fri Dec 04, 2009 1:15 pm
mine was can it tick if the gap was to small
leeparkes
Post Fri Dec 04, 2009 1:55 pm
M30's seem to run better with a bit of 'tick'
I adjusted mine to 0.25 by mistake, it was virtually silent but once id rectified my mistake and went to 0.30 the engine seemed more perky!
DRIFTBOY
Post Fri Dec 04, 2009 3:04 pm
STiBen wrote:Does it sound tickery martin?
A little bit, but not the worst I've heard.
Never managed to get it quieter so I don't worry about it now!
Driftben
Post Fri Dec 04, 2009 8:14 pm
Well u think it's only the hydrolic tappets which are quite quitet. Don't mind the sound as long as it runs when I'm finished with the rebuild :wink:
engine will be going it quite soonish.
6pot wilwoods front
4pot Porsche rear
