Lee Parkes' E30 Alpina B10.
leeparkes
Post Fri Mar 20, 2009 11:28 pm
Right,
Ive picked up a healthy 89 535i sport,insurance write off! (light scrape down the drivers side)
here's the spec:
manual
sterling silver
130k with history (recenty serviced)
air con (the fan will be used on the swap)
m-tech kit
m-tech steering wheel
m-tech suspension
black sports leather with rear blind and rear door blinds
LSD
K&N panel filter
green stuff pads
sachs clutch fitted 12 months ago
I paid £200 for the car
oh and £50 for the wheels off 'danthe' to get it on the trailer,
Here's the Pictures of it!
Rear door blinds winkeye
and one of the lump!
here's a sly pic of the E30 the M30 is going into
And yes the slipper locks up fine winkeye
I will be making notes all the way to the end of the conversion including the total cost,so far it owes me £250,i will break the car so that will bring some of the money back
Let the fragfest begin!
Today was 'engine out day'!
started at 8am this morning and i was cleared up by 2pm,minus a trip to the cafe and i forgot my breaker bar so had to pop home,so you could say it took me 5 hours to get the engine out onto the floor.
The only pain in the arse i came across was a gearstick lock thingy,not sure if it was factory fitted but it was welded to the gear selector rod and came out of the transmission tunnel about 3 inch's on the passenger side,i knew it would stop the engine being pulled out smoothly so it had to come off,i had to cut the metal around the gear stick on the top of the tunnel to get the angle grinder in there and wasted about an hour of scratching my head thinking the best way to tackle it!
Here's the offending item :(
after this ordeal it was plain sailing and everything went according to plan.
Job done.
The engine ill be removing from the E30 is a high compression M20/b25 with rebuilt head,new sachs clutch 6months (3K) ago along with new water pump,cam belt,etc...,it will be for sale soon and will be sold as a complete conversion.
Thats it for now but just before the m20 gets pulled out i will put the car on a weigh bridge to see its weight then put it on the same bridge when the M30 is in the to see how much weight the car gains,also in going to measure how much the front suspension drops with the big six in there because we all know these big lumps of pig iron are heavy.
Ill keep it updated as i go along with plenty more pics (and problems)
Post Fri Mar 20, 2009 11:35 pm
The project start's :cool: . Have you got all the bit's needed for the conversion, how long you reckon it's going to take you? I'll be keeping a close eye on this :D 8)
leeparkes
Post Fri Mar 20, 2009 11:45 pm
Got to get a few bits and pieces to get it in but i also want to change a few bits and do the sump gasket,its not leaking now but id rather do it now rather than later
i want it in and running before july
cant wait! i drove it round the trading estate for about an hour before i got to work on it and it pulls like a train,its a lot quicker than my 325i,loads of low down power!
Post Fri Mar 20, 2009 11:59 pm
It'll be even quicker in the E30 :twisted: :) . Ready in time for summer 8)
P.S. I have a 3.46 diff if your looking for a diff 8)
leeparkes
Post Sat Mar 21, 2009 12:01 am
ImysE30 wrote:P.S. I have a 3.46 diff if your looking for a diff 8)
Slipper?
Post Sat Mar 21, 2009 12:02 am
Slipper?
Not a slipper unfortunately, otherwise i'd be keeping it :)
leeparkes
Post Sat Mar 21, 2009 7:12 pm
ImysE30 wrote:
Slipper?
Post Sat Mar 21, 2009 7:24 pm
You don't need a slipper Lee, I don't have one and light starts in the dry are still awesome.
JULY????????
It should take all of 7 days if everything is there at a push.
If you need anything on the conversion, give me a shout as i'm off work for a few days after the 30th.
zaust
Zone day release
Post Sat Mar 21, 2009 7:26 pm
Suscribed....
M30 Tech 1 Touring on gas.
furbster
Post Sat Mar 21, 2009 7:33 pm
Good luck with the conversion!
I'll be keeping a close eye on this one. Do you use your E30 for trackdays? If so would be interested to see how the heavy lump affects the handling.
It's something I've been toying with for some time but do not want to compromise the handling as mine is just a track toy.
Cook318IS
Post Sat Mar 21, 2009 7:40 pm
lee you have a PM fella
leeparkes
Post Sat Mar 21, 2009 10:04 pm
Rav335uk wrote:You don't need a slipper Lee, I don't have one and light starts in the dry are still awesome.
JULY????????
A slipper is always nice though rav winkeye
ive give myself a couple of months to gather all the parts together and prep the engine before it goes in also i want the E34 broke and gone first,
im not sure if ive got everything off the E34 needed for the conversion though,ive got
engine/box/prop
loom/ecu/relays
accelerater cable
all coolant hoses
is there anything else i need?
furbster,i dont do track days but also im curious about the weight issue,ill keep you informed.
Post Sun Mar 22, 2009 10:16 pm
JULY????????
engine/box/prop
loom/ecu/relays
accelerater cable
all coolant hoses
Lee, thats about it mate apart from the rad, unless u have a e28 m535 one..Have u got a short shift for it yet???
leeparkes
Post Sun Mar 22, 2009 10:45 pm
Rav335uk wrote:Lee, thats about it mate apart from the rad, unless u have a e28 m535 one..Have u got a short shift for it yet???
The rad on the donor car isnt that old and looks about as thick as the m20 one,if you've got 5 minutes rav could you measure the thickness of your e28 rad for me? ive been reading that people have used the E34 rad
short shift is on my shoping list,previous owner of my car cut the original shifter and fitted a ripspeed chrome ball :?
e30_singh
Post Mon Mar 23, 2009 5:11 pm
Good luck with the swap, hope it all works well.
:wink:
Post Tue Mar 24, 2009 7:52 pm
Lee,i've used the origional e34 rad mate, makes it tight on the front if you need to change your dizzy cap etc and also the stat.
I didn't see the reason why i should spend £150+ for a e28 rad.
DRIFTBOY
Post Tue Mar 24, 2009 8:02 pm
Rav335uk wrote:i've used the origional e34 rad mate, makes it tight on the front if you need to change your dizzy cap etc and also the stat.
You might also need to remove the air con belt groove of the crankshaft front pulley, even in engine position three mine made contact with the radiator under heavy braking!
It's very easy, just run a cutting disc in a grinder around the centre of the 'V', this cuts through the welds and it comes away in two halves.
leeparkes
Post Tue Mar 24, 2009 8:12 pm
Cheers lads :thumb:
e30_singh
Post Tue Mar 24, 2009 8:28 pm
If you need any parts drop me a PM, I am breaking my one..
leeparkes
Post Tue Mar 24, 2009 8:57 pm
e30_singh wrote:If you need any parts drop me a PM, I am breaking my one..
pm sent
blackcountrybimmerman
Post Sat Mar 28, 2009 3:44 pm
I'm watching this one very closely.........
It doesn't look like it does in my sig pic anymore
Ziggy
Post Mon Mar 30, 2009 8:56 pm
I've got an open diff in my m30'd E30 at the moment.... and it is rubbish. Can't wait for the rebuilt LSD to get back where it belongs!
Change the sump gasket before it goes in.
leeparkes
Post Mon Mar 30, 2009 9:01 pm
Ziggy wrote:Change the sump gasket before it goes in.
Its on the ever growing list :thumb:
leeparkes
Post Fri Apr 17, 2009 7:45 pm
UPDATE:
Well first of all the donor car has gone after a fragfest and letting my 10 year old smash it up with an iron bar,
he was in his element lol
Owned
The frag list:(all sold) not inc post)
door cards with blinds £105
seats £80
M-tech kit £85
Slipper £120
suspension £50
Fuel out of the tank £30ish
Shell £40
Misc bits&bobs £95
Total £605
I still have greenstuff pads and other bits still to put on e-bay hoping to make around an extra £100 off them.
donor car got took last week.the gypo gave me £40 for it!
Right,got the engine home on the back of a mates trailer,not nice when you see an M30 bouncing around behind you and im glad it was only a 5 minute journey,
got to work on it,so far ive been mainly dressing it up with hammerite
Engine block is gloss black
inlet mani is hammered black which comes out a nice charcoal colour,
oil filter housing,alternater,thermostat housing,manifold mount and throttle body all done in silver,
Not sure what colour to do the rocker cover yet :?
Jobs left to do
Paint rocker cover
Adjust valves
Do the spray bar mod
Cut front pulley off
modify exhaust manifold
Sump gasket
then put it all back together ready to drop in!
Ill update again soon
DRIFTBOY
Post Fri Apr 17, 2009 7:53 pm
Looking gooooood! 8)
I bet your boy loved smashing that car, it's great for getting a bit of anger out too! winkeye
I started smashing my 535i donor car in front of a police woman (long story) but I really was very angry! :D
Why not do the rocker cover the same as the inlet? I think that would look smart! :D
Post Fri Apr 17, 2009 8:02 pm
Definitely going to be good when it's finished......
Give me a shout if you need me to pass any spanners to ya....lol
leeparkes
Post Fri Apr 17, 2009 8:51 pm
Cheers Alan^
Driftboy, i have been considering doing the rocker the same as the inlet but not sure yet and yes my lad loved smashing it up the donor car,it wasnt just the windows he done he kicked and smashed all the panels (check passenger wing) also got on the roof and stamped that in!
I launched an assault on it when i was pulling the engine out after cutting my finger with a hacksaw,
it helps to let your anger out on it winkeye
DRIFTBOY
Post Fri Apr 17, 2009 8:56 pm
Just go to 'edit post' on the first post of the thread and you can change the title there, I think! :?
leeparkes
Post Fri Apr 17, 2009 9:09 pm
DRIFTBOY wrote:Just go to 'edit post' on the first post of the thread and you can change the title there, I think! :?
Cheers!
Post Fri Apr 17, 2009 10:23 pm
Rocker cover should be the same colour as the inlet mani, will look nice :cool:
leeparkes
Post Fri Apr 17, 2009 11:23 pm
If i paint the rocker in hammerite i cant re-paint it another colour because other paints react on top of it and it would be a ballache to strip hammerite off a rocker cover with all the grooves etc...
the jury is out on this one till im 100% sure
Post Sat Apr 18, 2009 12:40 am
Highly polish it :twisted:
Nice work so far :) :thumb:
leeparkes
Post Sat Apr 18, 2009 12:45 am
ImysE30 wrote:Highly polish it :twisted:
Mmm.....
Post Sat Apr 18, 2009 12:47 am
Mmm.....
You know you want to, will look nice with the black IMO :)
DRIFTBOY
Post Sat Apr 18, 2009 2:57 am
Paint the rocker cover then go over the raised parts with a block and wet & dry, polish those and lacquer it, lovely! 8)
